understanding how to adjust headlights...
If you look carefully where the adjustment points are you will see a circle looking thing (circular disk about the size of a quarter) with an 8 or 10 mm bolt to use for adjustment. The circular disk is about the size of a quarter...
Or you can take a look at your owners manual... its in there.
Good Luck..
Good Luck..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra »</TD></TR><TR><TD CLASS="quote">use a #2 or #3(works better) phillips head screw driver to turn the dial a *****
Actually if you can get easy access to the bolts using a flexible adaptor, it is much easier to turn the discs by the bolts. With the phillips method, you are more than likely to just mess up the surrounding plastic, lowering the value of your headlight if for any reason you sell them in the future.
NRG
NRG
bestcivic
Aug 28, 2009 07:30 AM
4dr-Si
Mar 21, 2006 08:32 AM
