A/C Refrigerant
Old Oct 18, 2001 | 10:22 AM
sporter's Avatar
New User
Default A/C Refrigerant
Just curious. I was adjusting my actuator rod for my turbo and I was bending the a/c lines out of the way. Well after that it started spraying the refrigerant out all over the place. Just curious if this is bad for you to breath. I waited till it all leaked out but I inhaled a lot of it
Just a precaution.
Old Oct 18, 2001 | 10:45 AM
4WDrift's Avatar
Default Re: A/C Refrigerant (sporter)
Are you dizzy? It's not poisonous (unless burned, chlorine) but can cause suffocation in an enclosed / lowest point area due to lack of oxygen. You just lost $90 / lb. if it was R-12.
Gary
[Modified by 4WDrift, 2:52 PM 10/18/2001]
Old Oct 18, 2001 | 10:54 AM
sporter's Avatar
New User
Default Re: A/C Refrigerant (4WDrift)
A little naustious but nothing to worry about. Is it R12? I have a 94 civic. Don't think it's ever been changed.
Old Oct 3, 2011 | 09:46 PM
vreppeto's Avatar
The switch to r134 was not mandated until 1997 but some mfr's did it sooner. Some cars have been upgraded after market. Look for a sticker detailing r12 or r134a and a particular type of oil. if the schrader valve connectors for the ac system are quick connect then it is 134a and if they are threaded on the outside with a tapered tip then it is r12.
texas_tea_2k6
Jan 15, 2007 01:26 PM
lee
Aug 8, 2002 07:13 PM
hondachick81
Sep 10, 2001 08:03 AM
TreDEE
Aug 23, 2001 04:21 AM
