DA Radiator VS ITR Rad
Old Mar 11, 2004 | 12:00 PM
Blazeone's Avatar
Default DA Radiator VS ITR Rad
Well im in kind of a bind. When was doing my jdm front end i accidently put a drill bit through one of the fins and have a 1*1 mm hole in it, it can be fixed but i dont know if i can trust it or not. I have a DA LS parts car and i put the rads side by side and they seem exactly the same size(except the two bottom mounts, but can be modified to fit). I was wondering if it had the same cooling charachteristics as the ITR rad. The LS rad seems to have more deepth and beefier than the ITR rad.
So two options i have are to replace the rad with the LS rad, or get the stock ITR rad fixed.
This is only a temoparary replacement till i can afford a C&R rad.
Old Mar 11, 2004 | 12:09 PM
jonas's Avatar
dont know if they are exactly the same cooling wise..but i'm sure you'll be fine.
hell, i have a stock 97 civic radiator on my built ITR motor lol
Old Mar 11, 2004 | 12:21 PM
Bradstard's Avatar
Default Re: DA Radiator VS ITR Rad (BlazeONE)
I believe that FOrSfEd is running a DA radiator in his turbo ITR. PM him and ask.
Old Mar 11, 2004 | 01:52 PM
B2FiNiTY's Avatar
I have a feeling it won't fit since the ITR one won't fit in da's.
Old Mar 11, 2004 | 02:52 PM
Blazeone's Avatar
Default Re: DA Radiator VS ITR Rad (B2FiNiTY)
Aww screw it, im just going to order a GSR rad tommorow. Should be good enough!
Old Mar 11, 2004 | 03:06 PM
PM-Performance's Avatar
the opnly big diff is the bottom mounts, you can drill out the mounts and reweld them on where you want them . it should cool fine, i run a civic rad on my turbo R
sinister357
Apr 19, 2005 12:15 PM
B-money
Jul 29, 2004 06:15 PM
rated_r
Jul 19, 2004 03:32 AM
jdmekcivic2eg
Jul 9, 2004 01:44 PM
bruthaboost
Jul 3, 2002 10:33 AM
