does anyone use these mufflers....Aeroturbine??
Old Mar 11, 2004 | 11:41 AM
Chillinit's Avatar
Default does anyone use these mufflers....Aeroturbine??
Anyone running this muffler on the FI setup?? is so, how do u like them? they seem to perform extremely well...
http://www.aero-turbine.com/how/index.html
Old Mar 11, 2004 | 12:18 PM
RedTegLS's Avatar
Default Re: does anyone use these mufflers....Aeroturbine?? (Chillinit)
https://honda-tech.com/zerothread?id=795911
Old Mar 11, 2004 | 04:06 PM
Chillinit's Avatar
Default Re: does anyone use these mufflers....Aeroturbine?? (RedTegLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedTegLS &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=795911</TD></TR></TABLE>
well..that thread doesn't really help much...anyone else?
Old Mar 12, 2004 | 03:49 AM
Chillinit's Avatar
nobody is running this exhuast??
Old Mar 12, 2004 | 06:41 AM
Rollo Lawson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinit &raquo;</TD></TR><TR><TD CLASS="quote">nobody is running this exhuast??</TD></TR></TABLE>
**** that ****. bredren, the bottom line is, buy a muffler that flows well and sounds decent. if you plan on 1/4 mile racing, just drop the exhaust. i hate seeing these type of things. there is NO muffler out there that is leaps and bounds better than the other in terms of hp & tq. if you want maximum power, just make sure that your set up is efficient and tuned well. my boy had a str8 through muffler on his DA GSR and he ran 14.9's. when he replaced his muffler with a $60 chambered dynomax, he never ran worse than 14.7 and gained 2mph. was it the muffler? probably, but, he did go from a free flowing muffler to a chambered, more restrictive one. my point is this muffler **** is all b.s. make an e-cutout and done. peace
Modified by B16C1 at 4:26 PM 3/15/2004
Old Mar 12, 2004 | 06:51 AM
Daemione's Avatar
Default Re: does anyone use these mufflers....Aeroturbine?? (B16C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16C1 &raquo;</TD></TR><TR><TD CLASS="quote">. . . the bottom line is, buy a muffler that flows well and sounds decent. </TD></TR></TABLE>
I think the point of his question was to find out if that's the case with this muffler.
I'm not familiar with the aeroturbine, but in concept it looks similar to the Moroso spiral-flow - a small straight through portion down the middle w/ a few baffles in a spiral pattern around the outside. You'll find positive reviews of them from several different sources, but I've never had any luck finding any actual flow numbers. But it supposedly has better than average noise cancellation properties while retaining near straight-through flow.
But I'd be extremely skeptical of any claims that it actually accelerates exhaust flow . . . . And for $200, I don't think it's worth it.
Old Mar 15, 2004 | 05:13 AM
Chillinit's Avatar
Default Re: does anyone use these mufflers....Aeroturbine?? (Daemione)
up
Old Mar 16, 2004 | 02:24 PM
Chillinit's Avatar
nobody?
Old Mar 16, 2004 | 02:46 PM
LudeyKrus's Avatar
Never heard of them, but I don't like the design. Go w/ a straight through.
xxh3iiraz0rxx
27
Jun 3, 2007 07:29 PM
dfoxengr
Welding / Fabrication
13
May 14, 2006 08:09 AM
OoHiTzToMMy
Nov 11, 2004 10:45 AM
dohcMONSTER
Mar 1, 2004 02:20 PM
2.2motore
Feb 20, 2004 12:39 AM
