'95 v6 trouble code 92- EVAP system problem-what to check?
My wifes auto v6 accord w/160k miles served up a 92 trouble code which refers to a EVAP purge problem. Before I check it out, anybody have any past experience with this problem. Likely culprits?
Insufficient Purge Flow or Defective Emissions System
Can't be more than six things:
But you need a vacuum guage to accurately pinpoint the problem, but here goes.
1. Vacuum lines to the cannister are bad
2. EVAP purge selonoid is bad
3. Short between main relay and to the EVAP purge selonoid
4. Bad ecu
5. Bad ground to ecu
6. bad canister
fs
4. Bad ecu
6. bad canister
fs
