Honda's ZC engine??????
Old Oct 18, 2001 | 07:57 AM
SithPodz's Avatar
New User
Default Honda's ZC engine??????
I recently read in the Jackson Racing catalog about a Honda engine called the ZC. I have never heard of this engine before. All J.R. had to say about it was that it is a non-VTEC DOHC widely used in Europe and Japan, but has become a popular swap in the states. Does anybody know anything about this engine. I am very interested to know the displacemnet, horsepower, torque, etc, etc.. for this engine.
Old Oct 18, 2001 | 08:34 AM
EP3_05's Avatar
Default Re: Honda's ZC engine?????? (SithPodz)
I have one in my car. It is a 1.6L dohc non-vtec motor. It is rated at 130hp and 108 lb/ft of torque. It comes from the european and jdm civic si. It is pretty quick and good for low 15's in the quarter mile. I have seen some run in the 14's. It will bolt right into the 88-91 civic/crx and match up with the stock tranny. There is a pretty good selection of parts for it, if you look hard enough. What else do you want to know?
Old Oct 18, 2001 | 09:51 AM
Honda318dx's Avatar
Default Re: Honda's ZC engine?????? (91civic)
Whats the engine code for the ZC motors?
Old Oct 18, 2001 | 09:54 AM
VTC_CiViC's Avatar
Default Re: Honda's ZC engine?????? (Honda318dx)
ZC
Old Oct 18, 2001 | 10:29 AM
EP3_05's Avatar
Default Re: Honda's ZC engine?????? (VTC_CiViC)
It is also the d16a8 and d16a9.
Old Oct 18, 2001 | 11:15 AM
sackdz's Avatar
Anyone know the code for the 1st-gen 1.6L DOHC (non VTEC) Integra motor rated at 118hp?
Old Oct 18, 2001 | 11:23 AM
sackdz's Avatar
Default Re: Honda's ZC engine?????? (sackdz)
I think it was D16A_ who can confirm?
Old Oct 18, 2001 | 11:30 AM
EP3_05's Avatar
The code for the 1st gen zc (brown valve cover) is: d16a1
Old Oct 18, 2001 | 11:32 AM
Honda318dx's Avatar
Thanks, that was what i was looking for..
Old Oct 18, 2001 | 04:07 PM
976's Avatar
976
New User
On most honda engines they use the liter of the engine in the second two codes, such as B21A - hence it is a 2.1 liter engine.
Old Oct 18, 2001 | 05:17 PM
keithv's Avatar
I thought the first gen Teg motors was a D16A6.
[Modified by breaka_1_9, 9:18 PM 10/18/2001]
Old Oct 18, 2001 | 08:50 PM
VTC_CiViC's Avatar
Default Re: Honda's ZC engine?????? (breaka_1_9)
Ok let me clarify this:
The JDM ZC motor was just that, a "ZC", no numbers, no D-anything, just "ZC". The 1G USDM Integra used a D16A1 DOHC 1.6, the D16A6 was the 88-91 Civic/CRX Si SOHC engine. The D16A8/9, just like the D16A1 are basically twins of the JDM ZC (DOHC 1.6L engines) destined for other countries. But the actual JDM ZC is just that, ZC
Old Oct 19, 2001 | 05:34 AM
sackdz's Avatar
Old Oct 19, 2001 | 07:12 AM
SithPodz's Avatar
New User
91civic, Do you know if the ZC would fit in an automatic '94 Civic EX? And do you know if they made the ZC longer than to '91. Jackson Racing says it was in production until '98, but I havn't found anything newer than '91 anywhere else.
Old Oct 19, 2001 | 07:20 AM
WAFFLES's Avatar
you can fit a zc in an eg/ej no problem. In 91-92 Honda of japan produced a special edition civic in japan called the si. It was equipped with a ZC. NOW, the problem is finding a ZC for the eg chassis. You can use a ZC from the ef chassis and convert it to obd1 status(change distributors and injectors, and use a different ecu)I would also ditch the automatic tranny for a si/ex 5spd.
But don't swap in a ZC if you already have an ex. Sure there is DOHC tunability, but in stock form a ZC only has 5 more ponies than your ride.
Old Oct 19, 2001 | 07:39 AM
EP3_05's Avatar
Default Re: Honda's ZC engine?????? (sithpodz)
Yea, don't waste your time for a 5 hp increase. Go for either a b16 or a b18 swap. You will be much happier with one of those.
[Modified by 91civic, 4:41 PM 10/19/2001]
Old Oct 19, 2001 | 08:24 AM
SithPodz's Avatar
New User
thanx guys. I wasn't real serious about the ZC, just curious. Doing a swap is a little down the road for me. I had just never heard of the ZC and it caught my interest. Thanx for all of your help.
ludecrasy87
Nov 28, 2006 06:50 PM
vti_shifter
Jul 17, 2005 08:31 AM
SithPodz
Oct 18, 2001 11:46 PM
