2"+ lowered GSR = Clunk Noise Just before stop??
Old Mar 11, 2004 | 08:10 AM
NY_TegGSR00's Avatar
Default 2"+ lowered GSR = Clunk Noise Just before stop??
I just recently installed a H&R Cup suspension kit in my 00 GSR. I had a few problems with the install, but the final product is amazing!
--BEWARE---
The lower spring pearchs are adjustable on these things and they are NOT set in the right spot ( for the advertised lowering F 2.0 R 1.75 ) from the factory. The rear pearch must be lowered to the bottom setting. You can leave the front on the top setting - this will make about a -2" f&R setup. After finding out the hard way, i re-compressed both springs again (by hand) and reinstalled the shocks.
I also installed Benen F&R lower tie bars, Skunk 2 upper ctrl Arms, and SPC Rear tie rods (camber)
I now hear a clunk sound coming from the front left wheel somewhere, but only as i come to a stop - Near stopped (like 2mph and down) and just after i take off.
ITS NOT THE CV's so what could it be?
The skunk2 camber kit is by far the sweetest setup i have worked with!
I will try to post some pics of the car soon
Old Mar 11, 2004 | 09:50 AM
powerls's Avatar
I had kinda the same problem after I had my Tein basics installed... there was just something loose... I had to go in there and loosen everything and then tighten it all back down. Just get it up on a lift and check everything out. best of luck
Old Mar 11, 2004 | 10:31 AM
hypa's Avatar
Default Re: (powerls)
If you're not running the 2 x screws in your brake rotors, you may get a slight clunk as it moves in between the lugs. That's what my noise was caused by.
Old Aug 20, 2004 | 06:35 PM
Takumi Fujiwara's Avatar
Default Re: (hypa)
your rotor was moving even with the wheel torqued down to spec?
Old Aug 20, 2004 | 06:43 PM
.water's Avatar
Default Re: 2"+ lowered GSR = Clunk Noise Just before stop?? (NY_TegGSR00)
check ur install again..make sure everything is tighted right and check ur bump stop too..
Old Aug 21, 2004 | 08:29 PM
stumpyf4's Avatar
https://honda-tech.com/zerothread?id=838684
My noise was the Skunk camber kit, top for second page. Check your's in this area.
SportEL
Suspension & Brakes
Jun 30, 2009 05:04 PM
vgsr
May 29, 2005 09:26 PM
mrdanglez
Oct 4, 2004 04:49 PM
is3oo
13
Oct 25, 2001 12:30 AM
