88-91 ef back bumper lip???
i seen hella hacthes with a si front bumper lip mainly si's (duh) but i seen only a few hatch's with a lip on the back bumper...what year is that off of and is it a si lip too?? where can i get it at and how hard are they to find oh yea is there any one with pictures of it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec »</TD></TR><TR><TD CLASS="quote">
Man I hope my hatchie grows up to look like that. Very nice car
</TD></TR></TABLE>Man I hope my hatchie grows up to look like that. Very nice car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japrex »</TD></TR><TR><TD CLASS="quote">very hard to find...good luck!</TD></TR></TABLE>
if anyone is interested i can get the brand new. takes a few weeks but its honda and NEW! 278cdn
i have pics but my host is fucked anyone wanna post em for me....im me
cheers
Greg
cheers
Greg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "B18C5crx from cloudpump.net" »</TD></TR><TR><TD CLASS="quote">Well I have always wanted a rear lip on my crx and I had an 89 Si lip sitting around in my garage. I placed it up to the back of the 90 bumper and it looked like it would fit with some modification. So I went to work.
It wasn't that hard it just takes patience. I used assorted screws and bolts to hold it in place and a hair dryer to heat it up so it would keep shape. I also used a dremel with a cut off wheel to cut the lip in some spots to get it to bend correctly. Unfortunately my lip was cut up on the sides for some reason so it may look a little weird around the side edges.
First just grind off the little plastic tabs on the top of the lip so it sits flush with the bumper.
Then line up where you are going to make your cut for the exhaust. Make sure you leave enough plastic to fold into the exhaust cut out. This gives it a much cleaner look in my opinion. Cut the lip in that spot.
Then at one corner put a screw through the under side of the lip into the bumper cover, After you line it up and have it where you want it. This will hold that end in place.
This is when I heated the lip up and started to mold it to the bumper. Just rest the tabs where the lip was mounted stock along the bottom of the bumper. I used vise grips to keep it in place after I heated it up.
This also helps when putting the screw through to keep the lip from shifting. I had to cut some of the plastic off on the underside of the lip where it bends around the bumper, because the plastic was to hard to bend here. The hardest part was molding the plastic into the exhaust cut out. I had to grind away the top of the lip and the buttom so I could get a nice even bend. Then just put a screw through the lip into the bumper on the inside of the exhaust cutout. This is the only visible screw but it is very hard to see.
I will post pics of it on my car in a few days once I get some good pics of it.
-James-</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideout »</TD></TR><TR><TD CLASS="quote">holy rear camber batman!!! you drifting that thing
anyway looks good, but get that camber fixed before you go sliding sideways down the freeway
shut up.
</TD></TR></TABLE>shut up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonGSR »</TD></TR><TR><TD CLASS="quote">I think your car looks tight! I know it may not be the safest, but I love when the wheels bend in like that, looks dope!</TD></TR></TABLE>
thanks for the complement. but once again its safe. i drive 50+ miles a day. no bad camber wear. safe on freeway. its fine. but thanks for the compliment
i might try this rear bumper lip some time since i have a 90-91 si lip just sitting around and my 1st gen teg lip also. i wonder which one would look better..
OngChien
24
Sep 15, 2008 09:18 PM
ryucuhz
22
Jun 26, 2007 08:43 AM
