How good is a JDM D15b turbo?
Old Mar 11, 2004 | 07:18 AM
civic5483's Avatar
Default How good is a JDM D15b turbo?
I have a 92 civic hatchback vx.I wanna do a sohc vtec swap and go turbo, but how good are these motors?Should I just look for a d16z6 or y8 instead?I wanna hit atleast mid 13's in the 1/4 mile.
Old Mar 11, 2004 | 07:47 AM
Devine's Avatar
Default Re: How good is a JDM D15b turbo? (civic5483)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic5483 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 92 civic hatchback vx.I wanna do a sohc vtec swap and go turbo, but how good are these motors?Should I just look for a d16z6 or y8 instead?I wanna hit atleast mid 13's in the 1/4 mile.</TD></TR></TABLE>
jdm d15b makes the same horsepower as the z6 but has alot better powerband, have also seen more impressive numbers out of the d15b vtec on the dyno. The stock cam is basically the "type R" cam of d series, very similar to the zex 59300 cam. Internally the block is basically a vx block with stronger rods, the r/s ratio of the d15b is the same as that of a b17a, it revs very freely and impresses most people that ride in my car. I say go with the jdm d15b. With whatever motor you choose to go with you shouldnt have a problem hitting your quarter mile goals as long as you have a good set-up. Here is a pretty informative link about the motor, https://honda-tech.com/zerothread?id=585043
Old Mar 11, 2004 | 08:40 AM
Slammd Sol's Avatar
Default Re: How good is a JDM D15b turbo? (Devine)
I got a d15b vtec turbo.. Devine about said everything there is to say about the D15b
Old Mar 11, 2004 | 10:49 AM
kranked91dx's Avatar
same thing here, I got a JDM d15B turbo.
very strong little boy.
took several abuse over two year,
Compression is perfect across all 4 cylinder,
pull strong as hell
better power band and rod stroke ratio as it was said before
all in over all, one of the best SOHC availlable for modding.
Kranked
Old Mar 11, 2004 | 05:00 PM
civic5483's Avatar
Thanx i am gonna go with the d15b.Do you think it i will work good with a 97 dx tranny or should i look for an ex trans?
Old Mar 11, 2004 | 05:04 PM
b16ahybrid's Avatar
I would recomend the ex tranny
Old Mar 12, 2004 | 04:46 AM
Do a search on D serie turbo trany man,
I would recomment the EX tranny or a Hybrid one...
I'm running the SI tranny and the gear are so short... first is almost inexistant, second go trough pretty quick too...
see ya
Kranked
Old Mar 12, 2004 | 05:39 AM
Slammd Sol's Avatar
Default Re: How good is a JDM D15b turbo? (kranked91dx)
arnt Si and EX trannys the same except the 5th gear in some models?
Old Mar 12, 2004 | 06:35 AM
Default Re: How good is a JDM D15b turbo? (Slammd Sol)
the final gear determine the ratio.
some Ex trany got a gear other an overdrive,
Ask Mistabone if you want to get some clearer answer, I don't know wich model got what from the top of my head...
Kranked
RTCdominicano
87
May 21, 2019 09:48 PM
bazookatooth
Apr 5, 2005 03:20 PM
JoSi
Feb 14, 2005 08:12 PM
civic5483
24
Jan 30, 2004 08:09 PM
IamVtec
Feb 11, 2003 05:56 PM
