Suspension Tech's Lower strut and sway combo??
Old Oct 18, 2001 | 06:52 AM
Spade's Avatar
Default Suspension Tech's Lower strut and sway combo??
Anyone got this or better yet, anyone think that it is worth it? I don't know if you need a lower strut bar if you get a sway bar who has an opinion?
Old Oct 18, 2001 | 07:40 AM
WykidEH's Avatar
Default Re: Suspension Tech's Lower strut and sway combo?? (Spade)
If you don't need one. Then why does the ITR have one?
Old Oct 18, 2001 | 10:02 AM
Spade's Avatar
Default Re: Suspension Tech's Lower strut and sway combo?? (WykidEG6)
I didn't know that the ITR had a lower rear strut brace.
Old Oct 18, 2001 | 11:40 AM
fsp31's Avatar
For a street driven car with spring rates below 600 lbs or so...
Do you mean a lower tie bar? If it's for a an EK (96+) Civic, then it's pretty much a waste of $$$ and weight. Even a "upper" strut tower brace isn't going to make much difference. On the EG or 92-95 Chassis, CAD design is not quite as good so there's a bit more flex. An upper brace can make a difference, but the lower brace is still sort of a waste IMO.
maxis
Suspension & Brakes
Aug 29, 2011 08:48 PM
thambi23
Mar 13, 2008 05:15 AM
honda_coupe
Oct 24, 2005 07:25 PM
IntegraPrez
Oct 9, 2004 09:08 AM
mickey513
Apr 30, 2003 03:31 AM
