OT: Anyone work at a honda dealership?
Old Mar 11, 2004 | 02:01 AM
skafia's Avatar
25 Year Member
Default OT: Anyone work at a honda dealership?
I need to reset my ABS light in my S2000 [Don't ask] and I don't want to get ripped off with diagnostic charges or anything, I just basically need to hook it into the computer, and reset the computer.
Anybody help a brotha out?
Old Mar 11, 2004 | 03:31 AM
Jon D's Avatar
Default Re: OT: Anyone work at a honda dealership? (skafia)
Hmmmmm....wish i could help out but thats not my department!!
<---Who was the newest member of http://www.skafia.com yesterday!!
Old Mar 11, 2004 | 04:08 AM
nsxtasy's Avatar
H-T Order of Merit
Are you sure you can't do it yourself? Isn't there a procedure in the service manual to do it? You know, like resetting the check engine light - just pull the right fuse kind of thing.
Old Mar 11, 2004 | 04:10 AM
MattD@Stoptech's Avatar
Default Re: OT: Anyone work at a honda dealership? (nsxtasy)
Yah, j00 should be able to reset it j00rself....AFAIK only the SRS light needs to be reset by a dealer with a special t00l....so ABS reset should be doable.
BTW, what did j00 hit this time?
Old Mar 11, 2004 | 08:34 AM
skafia's Avatar
25 Year Member
Default Re: OT: Anyone work at a honda dealership? (El Pollo Diablo)
LOL, don't worry about it, wtf does AFAIK mean.
I tried to reset it myself once, but I fried a fuse cause something sparked! I thought I killed my imm0bilizer!
B18C-Rsi - Sweet!
Old Mar 11, 2004 | 08:37 AM
Chris N's Avatar
As Far As I Know = AFAIK
Old Mar 11, 2004 | 09:31 AM
r573's Avatar
Default Re: OT: Anyone work at a honda dealership? (Chris N)
try this,bro make sure you have your radio code,remove the positive and negetive battery termanles and hold them together for a min, then leave them disconnected for ten min this might work.If thers a problem it will go back on.
Old Mar 11, 2004 | 11:14 AM
Default Re: OT: Anyone work at a honda dealership? (r573)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r573 &raquo;</TD></TR><TR><TD CLASS="quote">try this,bro make sure you have your radio code,remove the positive and negetive battery termanles and hold them together for a min, then leave them disconnected for ten min this might work.If thers a problem it will go back on. </TD></TR></TABLE>
Why exactly are you holding the two cables together?
all j00 need is to disconnect the ground terminal from the battery and leave it off for a couple of minutes...
Old Mar 11, 2004 | 11:49 AM
type r 01-1063's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">AFAIK only the SRS light needs to be reset by a dealer with a special t00l
That doesn't need to be done at the dealer. Yes, you do need a special tool for the job. It's called a paper clip . Basically, resetting the SRS light is a DIY job.
Old Mar 11, 2004 | 01:02 PM
skafia's Avatar
25 Year Member
Default Re: OT: Anyone work at a honda dealership? (type r 01-1063)
Unplugging the negative cable won't work. The ABS information is stored in another place, not the ECU.
Old Mar 11, 2004 | 01:36 PM
Rob Dizzle's Avatar
b19coupe works at a hunduh dealership
might be acura though. i forgot
Old Mar 11, 2004 | 02:02 PM
Eluder200K's Avatar
Contact this guy "Hondatec38" (Honda mech and S2k owner)
He will definitely know
Old Mar 11, 2004 | 02:16 PM
ITRbroham's Avatar
shit post warrior
Default Re: OT: Anyone work at a honda dealership? (Eluder200K)
Shouldn't this be in the S2000 forum?
Old Mar 11, 2004 | 02:22 PM
ZygSpeed's Avatar
Default Re: OT: Anyone work at a honda dealership? (ITRbroham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRbroham &raquo;</TD></TR><TR><TD CLASS="quote">Shouldn't this be in the S2000 forum?</TD></TR></TABLE>
LOL! Hmmm ... what a bright idea?
Old Mar 11, 2004 | 03:52 PM
Eluder200K's Avatar
Default Re: OT: Anyone work at a honda dealership? (zygspeed)
Now there's a thmart idea
Old Mar 11, 2004 | 04:24 PM
kingK's Avatar
u need to diconect both neg and pos on battery
Old Mar 11, 2004 | 04:27 PM
Hondatec38's Avatar
You Raaaaaaaaaang?
Press and Hold the select and reset buttons before starting the car. While holding the two, turn the key on and keep holding the buttons until the light resets (when it goes out) Then enjoy your clean, neat, and tidey instrument panel.
Oh wait. You said ABS light. **** sorry mang. Usually ABS codes will instantaniously come back when the circuit tries to prove out. You really need to see what the code is and then I can really help you. Sorry about the maintence required proceedure.
Old Mar 11, 2004 | 04:29 PM
nightrider's Avatar
Default Re: OT: Anyone work at a honda dealership? (Hondatec38)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondatec38 &raquo;</TD></TR><TR><TD CLASS="quote">You Raaaaaaaaaang?
second best suggestion.
Old Mar 11, 2004 | 04:30 PM
Hondatec38's Avatar
Default Re: OT: Anyone work at a honda dealership? (nightrider)
EDITED. Sorry.
Old Mar 11, 2004 | 04:32 PM
nightrider's Avatar
what? edited? isn't that the way you reset the maintenance required light?
edit: oh crap, i need to read too!!! ha ha ha. ABS LIGHT EVERYONE!!!
Old Mar 11, 2004 | 06:08 PM
APEX i GSR's Avatar
does the newe S2K have side airbags
if so it has to be initialzed with the Honda PGM tester
if it doesn't IM me tomorrow & i will email you the instructions
Old Mar 11, 2004 | 06:22 PM
kepani's Avatar
shouldn't you be in the s2000 forum?
kepani-who kids lloyd and hopes he won't beat the !@#$ outta him...
Old Mar 11, 2004 | 06:43 PM
ITRbroham's Avatar
shit post warrior
Default Re: OT: Anyone work at a honda dealership? (kepani)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kepani &raquo;</TD></TR><TR><TD CLASS="quote">kepani-who kids lloyd and hopes he won't beat the !@#$ outta him... </TD></TR></TABLE>
Nah......I'm gonna' steal your flip flops and make you chase me up and down the street!
Old Mar 11, 2004 | 08:44 PM
b19coupe's Avatar
Disconnecting the battery and holding the cables together might clear the code; it allows the capacitors to discharge. The code can be cleared with the PGM-Tester, but there should be an alternate method too. I would have to look up the procedure in an Acura S.M. on Monday (should be the same as Honda), I will be at Fontana this weekend and won't be back at work until then, sorry.
Old Mar 11, 2004 | 10:49 PM
skafia's Avatar
25 Year Member
Default Re: OT: Anyone work at a honda dealership? (b19coupe)
Thanks for all of the replies guys!
The S2000 forum sucks, it's all about the ITR forum, y0.
