JDM DC5R brakes for DC2/8 EK/EG
Old Mar 11, 2004 | 12:22 AM
Dee's Avatar
Dee
Default JDM DC5R brakes for DC2/8 EK/EG
I thought you guys might want to take a peep at this ultra expensive kit.
Front kit is 293,700yen (2,651.68 USD at today's yen rate)
Comes with:
DC5R Calipers
DC5R Rotors
DC5R pads
DC5R hubs
hub bearing
caliper retaining bolts and washers
Here's the link if you have Japanese IME loaded.
http://www11.ocn.ne.jp/~kuroki/kitnaiyou.html
Old Mar 11, 2004 | 12:53 AM
PeteBest's Avatar
Default Re: JDM DC5R brakes for DC2/8 EK/EG (Dee)
Nice.... These brembo's really stop you, very good on the track next to no brake fade
Old Mar 11, 2004 | 12:56 AM
type r 01-1063's Avatar
I want one!
Old Mar 11, 2004 | 02:11 AM
nightrider's Avatar
that's pretty freakin' pricey though.
Old Mar 11, 2004 | 03:13 AM
Darkteg's Avatar
New User
Default Re: JDM DC5R brakes for DC2/8 EK/EG (nightrider)
hmmm.. 17" minimum?
Old Mar 11, 2004 | 03:56 AM
Dee's Avatar
Dee
Default Re: JDM DC5R brakes for DC2/8 EK/EG (Darkteg)
16" wheels fit and some 15" wheels will also fit.
Old Mar 11, 2004 | 04:12 AM
Philly_NBP_R's Avatar
wish I could afford that bling
Old Mar 11, 2004 | 04:27 AM
swlabhot's Avatar
Default Re: JDM DC5R brakes for DC2/8 EK/EG (Philly_NBP_R)
I'm not feeling the look of the Brembo caliper. Much prefer Spoon.
What size are those disc/rotors?
Old Mar 11, 2004 | 04:34 AM
MattD@Stoptech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee &raquo;</TD></TR><TR><TD CLASS="quote">I thought you guys might want to take a peep at this ultra expensive kit.
Comes with:
DC5R Calipers
DC5R Rotors
DC5R pads
DC5R hubs
hub bearing
You're much better off going with something like Stoptech's kit for the ITR. The rotors flow better, they are a fully floating design which significantly reduces thermal stress on the rotors (and helps preventing warping.) The calipers are stiffer and deflect less than brembo units, and the whole thing costs a lot less.
A much better choice in my opinion.
"Acura Integra Type R 1997-2001 Brake Kit - Front, 2 Piece Floating Directional 328mm x 28mm Drilled or Slotted Rotors, with 4 Piston ST40 Calipers, Stainless Steel Brake Lines, AXXIS Ultimate Brake Pads - Anodized Black Calipers."
"$1795.00 - Item No. 83-054-4300 "
Old Mar 11, 2004 | 04:58 AM
magic hat #9's Avatar
Default Re: JDM DC5R brakes for DC2/8 EK/EG (El Pollo Diablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">
"$1795.00 - Item No. 83-054-4300 "</TD></TR></TABLE>
http://stoptech.com/
i agree with the chicken. stoptech isn't as well known in the honda crowd, but they are a top (if not the top) quality manufacturer of aftermarket brakes. at sema, even the brembo guys were gawking at the stoptech goodness.
also, that brembo setup was made for a dc5, not the dc2. the stoptech kit is made to specifically work as a cohesive package with the R's oem rear brakes. you can't just slap on some big front brake kit and expect it to work better than oem. you can easily shift the brake bias forward, causing your front brakes to do all the work and your rear brakes to do very little to help, and make your stopping distance *longer*!
Modified by magic hat #9 at 9:15 AM 3/11/2004
Old Mar 11, 2004 | 05:14 AM
Kengs's Avatar
Default Re: JDM DC5R brakes for DC2/8 EK/EG (magic hat #9)
FWIW, here's the guy's auction on Yahoo Japan:
http://page.auctions.yahoo.co....43728
I'll stick to NSX calipers and 28mm rotors thank you.
Old Mar 11, 2004 | 08:39 AM
Big Phat R's Avatar
Default Re: JDM DC5R brakes for DC2/8 EK/EG (kengs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kengs &raquo;</TD></TR><TR><TD CLASS="quote">I'll stick to NSX calipers and 28mm rotors thank you.</TD></TR></TABLE>
And 15" R compounds too!
Old Mar 11, 2004 | 02:34 PM
Dee's Avatar
Dee
Default Re: JDM DC5R brakes for DC2/8 EK/EG (Big Phat R)
I'll stick with my setup that works on with most aftermarket 15" wheels!
$1500 SS Works big brake kit:
Nissan Skyline R32 GTS-T Type M 4 piston caliper
Milled aluminum adapter bracket
300mm Mugen (S2000) rotor
Yes, the rotor is backwards because this is a shot from the test fitting a couple years ago. The calipers have since been painted black and the ground off "NISSAN" spot is now smooth.
Old Mar 11, 2004 | 02:42 PM
DC5RK20A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee &raquo;</TD></TR><TR><TD CLASS="quote">I'll stick with my setup that works on with most aftermarket 15" wheels!
Did you finally get them on. Haven't really looked at your car parked over there at the G-6 building. Just glanced when passing by. Lost my license for 45 days yesterday. Have to do some paperwork for limited privileges to and from home and work. All for going 72mph on the expressway, damn these ridiculously slow speeds here. Though I do love it here!
Old Mar 11, 2004 | 02:54 PM
Dee's Avatar
Dee
Default Re: JDM DC5R brakes for DC2/8 EK/EG (DC5RK20A)
I put them on and took them back off again. I'm waiting for my new rims to arrive so I can put the center locks in storage.
115kph in an 80kph zone! That sucks. Stay away from Kadena AFB base becauase they are issuing tickets for everything and ANYTHING. They tried to give me a ticket for my rollcage and lack of a back seat again while Igy got a ticket for having his license plate mounted on the right side of his car .
Old Mar 11, 2004 | 03:04 PM
DC5RK20A's Avatar
What the *****? Yeah I do not tread on to that place unless I positively have to. I hate that damn place, yesterday my gf was stuck at the gate for 1 hour because they just decided at 4:30 to lock down the gates. If any AF people here sorry, but the AF sucks *****!
Old Mar 12, 2004 | 04:55 AM
Darkteg's Avatar
New User
Dee, any other pics of that setup?
Old Mar 12, 2004 | 06:25 AM
Kengs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darkteg &raquo;</TD></TR><TR><TD CLASS="quote">Dee, any other pics of that setup?
This is what the calipers look like; I have a pic of the complete setup on an older computer...
43!
Mar 16, 2016 02:41 PM
Integra21
Feb 15, 2009 01:09 PM
DA9Rood
Sep 1, 2006 01:04 AM
1.8
Apr 1, 2006 03:12 AM
