EF9 w/b16a Axle Problem
We put the b16a in and bolted the hubs back on and put the wheels back on......the car wouldn't move in any gear even nuetral..we put it back in the air and they still don't move....we took apart the axle nut and knocked it out a little bit and now it turns, tightend it up again and won't turn!!! We are using the axles that came with the motor swap, it looks like the seal at the end is collaped. should we get new axles or will it still happen....please let me know.
Thanks,
Redsun Autosalon
Thanks,
Redsun Autosalon
Are you sure that the axles that came with the swap are correct? If they are 90-93 Teg axles you have to remove the dust shield ring on the backside of the hub. Id give that a shot and see what happens. Good luck!
integrawow
Jun 13, 2007 09:34 PM
