How to remove valve cover?
Old Mar 10, 2004 | 11:03 AM
bigslimdog's Avatar
Default How to remove valve cover?
I already searched and couldn't find anything. I need to remove my valve cover and also reinstall it. Can anyone give me detailed instructions and what to do? Also what materials and tools I will need? TIA
Old Mar 10, 2004 | 11:05 AM
Ricey McRicerton's Avatar
Default Re: How to remove valve cover? (bigslimdog)
There are a couple of bolts you can see from the top of the valve cover. Undo them and then pull the valve cover off (after you pull the spark plugs). I'd pick up a new gasket incase you rip the one you have on there. Also, retorque the bolts to 7.2 ft/lbs.
DONT OVERTIGHTEN THEM OR YOU ARE GOING TO END UP WITH A STUD BROKEN OFF IN THE HEAD!!! I've seen a few too many of those threads already.
Modified by Ricey McRicerton at 3:23 PM 3/10/2004
Old Mar 10, 2004 | 11:06 AM
bigslimdog's Avatar
Default Re: How to remove valve cover? (Ricey McRicerton)
Don't all the spark plugs have to go in the same spots again?
Old Mar 10, 2004 | 11:07 AM
umm...the wires have to go back into the same spots..but you can put a plug from cylinder one back into whatever cylinder you want. All of them should be seeing the same wear anyways.
POE's Avatar
POE
yes make sure u put them in the right way, i dont know how u could switch um up though..
Old Mar 10, 2004 | 11:08 AM
POE's Avatar
POE
ddfsgsdfg
Old Mar 10, 2004 | 11:11 AM
Default Re: (Vtecin94dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecin94dx &raquo;</TD></TR><TR><TD CLASS="quote">seems wierd has 212 post but doesnt know how to remove his valve cover.</TD></TR></TABLE>
Seems weird to me that you keep giving out misinformation and have twice as many posts as him.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecin94dx &raquo;</TD></TR><TR><TD CLASS="quote">yes make sure u put them in the right way, i dont know how u could switch um up though..</TD></TR></TABLE>
No, the plugs are universal, as I already said.
And btw, we all had to start somewhere. I still ask n00b questions and have a ton of posts. When are you guys going to find out that post count means dick?
Old Mar 10, 2004 | 11:16 AM
POE's Avatar
POE
Default Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
And btw, we all had to start somewhere. I still ask n00b questions and have a ton of posts. When are you guys going to find out that post count means dick? </TD></TR></TABLE>
im picking up what u are laying down, my bad bro, i smell what u are stepping in, i smell and inhale what u are smokin, my bad
BTW dont over tighten them valve cover bolts they break easy, good luck, i love u
Old Mar 10, 2004 | 11:23 AM
bigslimdog's Avatar
I was pretty sure that I already knew how to do it but I would rather ask a dumb question to make sure than not ask at all and **** it up. Now I see why your post count is up to where it is because you post stupid **** comments like this in people's threads where they are trying to get help.
Old Mar 10, 2004 | 11:26 AM
bigslimdog's Avatar
Default Re: (bigslimdog)
But anyways...thanks Ricey for some information that actually relates to my question. To Vtecin94dx, please reference my avatar.
Old Mar 10, 2004 | 11:30 AM
SOHC_MShue's Avatar
damn Ricey you got a lot of posts. Yea definantely make sure you don't torque those bolts down too tight. I broke one before and my friend has broken one by working on my car. Also they are a biatch to get out of the head
Old Mar 10, 2004 | 12:58 PM
sinatra's Avatar
not sure which one your's is in the picture.
Tools
1. Beer
2. 10mm socket with an extension
3. Hands (two preferably)
4. did I say beer?
Removal Procedure
1. Remove the bolts
2. Remove the spark plug wires
3. Drink beer
4. Pull up on the valve cover as you move it side to side/up and down (kind of a rocking motion to losen it. You don't want it to come flying off and knock over your beer)
5. Check the valve cover seal to see if it needs to be replaced, you can tell if it is cracked.
6. Place valve cover on a clean towel
7. Finish beer
Installation procedure
1. Clean the surface that the valve cover seal sits on (the seal itself and the top of the head.
2. Place small dabs of Honda Bond at the corners where your cam seals and distributor are. (Basically at the base of the half moons on your valve cover)
3. Open the other beer
4. Place the valve cover on the head. Be sure the holes are lined up.
5. Replace spark plug wires
6. Replace bolts. Torque them down to approx 7 ft lbs. (Basically Hand tight. You don't need to crank on these things like Godzilla.)
7. Finish your beer in success!!
I have probably left out key parts, like pissing and what not. I think you can figure the rest out.
Old Mar 10, 2004 | 01:01 PM
dsadas89das78934's Avatar
also, if you over tighten, you may end up with a stripped out stud hole in the head. (i have one now... not my fault though)
Old Mar 10, 2004 | 01:33 PM
cccya's Avatar
Default Re: How to remove valve cover? (sinatra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinatra &raquo;</TD></TR><TR><TD CLASS="quote"> Tools
1. Beer
4. did I say beer?
Removal Procedure
1. Remove the bolts
3. Drink beer
7. Finish beer
khmers0uljah
Jul 21, 2009 01:45 PM
stuie08
Aug 14, 2007 12:01 AM
standbackimapro
Dec 16, 2005 11:07 AM
Dirk McGirk
Oct 5, 2003 05:56 PM
ActiveAero
Jun 7, 2003 02:31 PM
