what should i use to get to here?
Ive got a mostly stock b16 with skunk2 stage 2's
I want to get to an 11.5 cr. And I already have a 55 shot dry kit I wanna be able to use at the track or once in a blue moon.
What kind of pistons should I use? Can my block handle this stock? Injectors? 93 octane ok?
Any aftermarket forged piston will work for you...forged pistons will be able to handle the additional heat that will occur when you up the compression or add nitrous.
You stock sleeves (block) will be fine with the set-up you are describing. As for injectors...do you have any kind of fuel management? The stock injectors will be fine but it never hurts to buy bigger injectors and run them with some kind of fuel management.
11.5:1 will run fine on 93 octane
Hope that answers some of your questions
thanks ur reply was exactly the kind of help im lookin for.
ive got all the parts for an obd0 --> obd1 conversion, then i plan on gettin the base hondata unit.
i need to know what exact pistons to get though. all of the ones i see say theyre 9:1 compression for turbo aps, i need to go the other way. i just wanna make the most out of the basic setup that i have and leave it at that, i dont plan on runnin 12's or nething.
Any additional help? thanks again.
There are several companies that will make a good piston. I personally use JE Pistons
http://www.jepistons.com/sportcompact.asp
Give them a call and speak with Tony. He'll be able to guide you to the right piston for you.
Good luck!!
Good luck!!
