Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
H1 roll cage question
Old Mar 10, 2004 | 05:36 AM
Civic44's Avatar
Default H1 roll cage question
After looking at the HC (NASA) rules, I notice that roll cages must be maximum 6 point (+2). Is this the case in H1 as well? I have an H1 type car that would not be competitive (I am not building it for H1 since the closest ECHC race is 600 miles away from me) and I am having the cage built in the coming days. The builder, who is also my sponsor (TRAC Racing), has offered to build me a pimpy World Challenge type cage which will stiffen the chassis considerably (going against the spirit of the HC rulebook) and which will be FIA approved. I am mainly running with EMRA and FAQ (Quebec club) where this is not an issue, but I wanted to know if I ever showed up at a NASA event, will my car which is otherwise H1 legal be rejected on the basis of the cage? Would the chief scrutineer possibly approve a FIA-spec cage which is clearly as safe as a NASA spec cage? It's not like I'm gonna beat anyone with my stock B16, but I'd like to be able to run NASA enduros in the future. Thanks.
Old Mar 10, 2004 | 05:44 AM
.RJ's Avatar
.RJ
Default Re: H1 roll cage question (Civic44)
http://www.honda-challenge.com/contact/
Old Mar 10, 2004 | 06:21 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
FIA does not require a diagonal brace in the main hoop (run from driver side roof to passenger side floor).
NASA requires this diagonal brace. They *might* make some exception but you really need to talk to them directly and see how flexible they are on this rule.
Old Mar 10, 2004 | 06:34 AM
JeffS's Avatar
To start with... you must be looking at an outdated version of the HC rules. Download the current ones from here: http://www.nasaproracing.com/r...c.pdf and start over.
Among other things, there is no attachment point limit.
Old Mar 10, 2004 | 08:19 AM
mstewar's Avatar
HC rulebook allows for chassis stiffening with the cage.. there's nothing wrong with doing that.. i'd say a good cage SHOULD do that..
Old Mar 10, 2004 | 08:22 AM
Civic44's Avatar
Default Re: H1 roll cage question (JeffS)
Indeed, it seems I was not looking at the right rulebook. Thanks. I was not worried about having too few bars, but rather too many contact points and now I see that that is not an issue. I will definitely have the minimum NASA bars plus others.
poison
Jul 11, 2006 04:40 PM
Quik Chris
Jan 24, 2006 04:41 PM
random-strike
11
Aug 10, 2004 01:01 AM
6ghatch
25
Dec 23, 2003 10:58 PM
civicrr
24
Jan 14, 2003 10:56 AM
