TYPE R CAMS VS. ZEX QUICKTIME STAGE3 CAMSHAFT
Old Mar 9, 2004 | 07:38 PM
kenepo_vtec's Avatar
Default TYPE R CAMS VS. ZEX QUICKTYME STAGE3 CAMSHAFT
LET ME KNOW WHICH OF THIS ARE THE BEST CAMS FOR MY CRX...LS/VTEC PROJECT (ALL MOTOR). TYPE R CAMS OR ZEX QUICKTYME STAGE3 CAMS????
Old Mar 9, 2004 | 07:57 PM
importboi22's Avatar
Default Re: TYPE R CAMS VS. ZEX QUICKTYME STAGE3 CAMSHAFT (kenepo_vtec)
compression, bore , pistons, headwork, header , exhaust , intake manifold, throttle body, any milling or decking? then i think we can help you a little bit... oh ya what valve train too?
Old Mar 9, 2004 | 08:08 PM
Default Re: TYPE R CAMS VS. ZEX QUICKTYME STAGE3 CAMSHAFT (importboi22)
B18A: I HAVE PR3 PISTONS, HEADER, EXHAUST, B16A HEAD STOCK, 7.5LB FLYWHEEL, YS1 TRANNY
Old Mar 9, 2004 | 08:36 PM
b18c-93's Avatar
New User
zex 3
Old Mar 9, 2004 | 08:55 PM
rods, engine managment and valvetrain?
Old Mar 9, 2004 | 10:26 PM
JDM2ndGen's Avatar
i never knew that zex made cams for b series i thought only single cams ...whats the 3 for ...they comes in different stages ? and like said before what valvetrain are you running ?
Old Mar 13, 2004 | 04:03 PM
KilaB18C's Avatar
Default Re: TYPE R CAMS VS. ZEX QUICKTYME STAGE3 CAMSHAFT (JDM2ndGen)
I hope there cams are better than there nitrous
Old Mar 13, 2004 | 10:31 PM
b18jdmteg's Avatar
if i were you i would go with the zex stage 2 cams , i have built 4 b16's now with zex cams and zex spring and retainers and all of them were all motor and put 200 whp to the ground and they were only running 10:5-1 compression, i am actually putting a motor together for my car using the zex stage 2 cams , in my opinion zex makes the best bang for your buck when it comes to camshafts...
Old Mar 16, 2004 | 05:10 PM
91civicDXdude's Avatar
zex/comp definately. R cams are OEM. they are a *little* better than stock.
Old Mar 22, 2004 | 06:40 AM
HRED's Avatar
Default Re: TYPE R CAMS VS. ZEX QUICKTYME STAGE3 CAMSHAFT (b18jdmteg)
Are you sure you can use Zex valve springs with stage 2 cams ? because, with single springs at exhaust and 11.5mm of lift, i broken the engine at 8600rpm !
I advice to not use zex valve springs.
But these cams are very powerull !
Old Mar 22, 2004 | 07:56 AM
88civichbz6's Avatar
i'm running the whole zex cam and springs and retainers in my z6 and have had no problem yet
Old Mar 22, 2004 | 10:57 AM
HRED's Avatar
Default Re: (88civichbz6)
Hum.. yes but z6 don't take 8800rpm and don't have 12.4mm of lift intake and 11.4mm exhaust...
I think there is a real problem with springs for DOHC Vtec
Old Mar 22, 2004 | 10:59 AM
dsadas89das78934's Avatar
true... comp cams only makes single springs, not duals like the b-series seems to need to handle their revs... but for a SOHC, their single springs seem to work out just fine.
Old Mar 22, 2004 | 11:02 AM
HRED's Avatar
Default Re: (soccaian)
ah ! so what valves train can we use safely with these cams ?
I think to use RM springs and retainers...
Jdmb16sir2
Aug 13, 2006 06:36 PM
BlackRocket
Dec 21, 2004 06:37 PM
6thgen_H22accord
Mar 1, 2004 01:08 PM
