need help throttle cable
Old Mar 9, 2004 | 07:19 PM
IVI's Avatar
IVI
Default need help throttle cable
i have a 96 integra with a b16 motor. the throttle cable right now doesnt fit right, its zip-tied. what cable do i need to get to make it fit right so i can adjust the idle? thanks.
Old Mar 9, 2004 | 07:32 PM
mr.beeks's Avatar
Default Re: need help throttle cable (IVI)
its zip tied cause its longer or shorter ?
what type integra?
ls, gs or gsr..
Old Mar 10, 2004 | 06:22 PM
IVI's Avatar
IVI
Default Re: need help throttle cable (mr.beeks)
shorter
Old Mar 10, 2004 | 06:54 PM
SuzukaBlueAP2's Avatar
explain this a little more. Which cable is shorter ? the B16 or your integra one ?
what model teg is it ?
Old Mar 12, 2004 | 06:26 PM
IVI's Avatar
IVI
Default Re: need help throttle cable (ScreaminTeg)
the cable i have in my car right now im guessing its a b16 cable. im not sure, i was wondering if anyone knew previously which cable is shorter / longer. the cable is short so the nuts that are supposed to go onto the bracket cant because its too short so rather than being screwed its zip-tied. i took off the throttle body and messed with the spring and now i need to get a new cable because my idle is way off. so i needed to know which cable should i get? its a db8 integra.
Old Mar 12, 2004 | 08:01 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Try an ITR cable.
Old Mar 24, 2004 | 10:12 AM
IVI's Avatar
IVI
Default Re: need help throttle cable (Gee3)
are you sure an itr cable will fit? i heard something about the throttle being backwards on gsr throttle bodies. the dealer doesnt have either the gsr is out of stock and the itr is special order. anyone have any other ideas? thanks.
Old Mar 24, 2004 | 12:00 PM
dc4rider's Avatar
u need a ls or type r cable cuz its longer the b16 head is all most like the ls so is should work
Old Mar 24, 2004 | 12:02 PM
dc4rider's Avatar
Default Re: need help throttle cable (src-rider)
gsr cable is shorter your car proboly have a gsr cable on it right now
Old Mar 25, 2004 | 07:08 AM
IVI's Avatar
IVI
yesterday i took out hte throttle cable, the one in the car was longer but the nut spots dont line up with the bracket. the way it is in the car now is from the fire wall it comes around and goes near the brake master cylinder(because its so long), then i zip-tied it to the a/c line and followed it through the bracket, zip tied it to the bracket, and into the throttle body. the problem is, its only secured by zip-ties.
http://ms0834.tripod.com/throttle.jpg
Old Mar 26, 2004 | 09:56 AM
dc4rider's Avatar
u need a ls throttle cable for sher
Old Mar 26, 2004 | 09:59 AM
dc4rider's Avatar
wat city u from if im close to i'll give u a hand
Old Mar 28, 2004 | 06:00 PM
IVI's Avatar
IVI
im in new jersey
Old Apr 8, 2004 | 02:31 PM
IVI's Avatar
IVI
just to let everyone know a 94-01 integra ls throttle cable fit. also a honda delsol throttle cable will also fit same part numbers.
Old Apr 8, 2004 | 02:46 PM
ProJectCvic's Avatar
make a bracket to extend or shorter to meet your need. It's cheapest way. I use my dx throttle cable for my b18b swap. I"ll take a pic if i get a hold of a camera.
Old Apr 8, 2004 | 02:54 PM
IVI's Avatar
IVI
Default Re: need help throttle cable (ProJectCvic)
i tried the bracket, all it did was waste 10 dollars and 3 hours.
Mixmasta
Jul 14, 2008 06:30 AM
civic889802
10
Dec 27, 2005 12:15 AM
vtakk eg
Jul 15, 2004 06:13 PM
bseries_beast
Jul 2, 2004 09:25 PM
2k2S4
Jan 11, 2004 12:16 PM
