Lightweight crank pulley - increase power?
Old Mar 9, 2004 | 05:38 PM
Edward's Avatar
Default Is lighted crank pulley really increase power??
I am ready to buy crank pulley from e-bay. I want to know how's different with the lighten crank pulley. I also ready buy CAI system. Is that nesscesary?? What brand do you prefer?? Thanks a lot!!
Old Mar 9, 2004 | 05:53 PM
sgT's Avatar
sgT
Default Re: Is lighted crank pulley really increase power?? (Edward)
lighten crank pulleys help just like a lightened flywheel
short tube intakes will make more power than long tube "cold air" intakes
Old Mar 9, 2004 | 06:27 PM
SleepnCiViC's Avatar
its not necessarly that it will make more or less power, they jus make power in different ways
Old Mar 9, 2004 | 06:43 PM
sgT's Avatar
sgT
Default Re: (SleepnCiViC)
example: aem vs js racing
aem in blue
Old Mar 9, 2004 | 07:06 PM
Edward's Avatar
Default Re: (sgT)
Which line is aem?? Thanks a lot!!
Old Mar 9, 2004 | 07:16 PM
Erik95LS's Avatar
Default Re: (Edward)
AEM is blue (like he said)
Old Mar 9, 2004 | 08:43 PM
itr1244's Avatar
Default Re: (Erik95LS)
yeah. one reason i went j's racing from aem.
j's
Old Mar 10, 2004 | 07:38 AM
goern-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Edward &raquo;</TD></TR><TR><TD CLASS="quote">I am ready to buy crank pulley from e-bay. I want to know how's different with the lighten crank pulley.
check out http://www.superiorracing.com
They have a b-series crank pulley that is the same design as the CTR pulley.
Old Mar 10, 2004 | 12:29 PM
myhatchrips's Avatar
Default Re: Is lighted crank pulley really increase power?? (sgT)
i had a short ram intake and i actually loss power. i think it varies depending on your specific setup. ill stick with my cold air system
Old Mar 10, 2004 | 12:51 PM
MK Ultra's Avatar
The biggest advantage to a lightweight crank pulley is increased engine responsiveness. You should see some slight power gain as a result of reduced parasitic drag, but the increase in power is virtually insignificant compared to the effects of a more freely revving motor.
As for intakes, I've gone from an RS Akimoto short-ram, to an AEM CAI and now back to stock. My advice is not to bother with aftermarket intakes. I am most satisfied with the OEM airbox. If you need the virtually imperceptable increase in power you get from an intake you can always remove the airbox and resonator tubing from the stock system.
fogged306
May 15, 2008 05:17 AM
civicek00
Jul 23, 2005 08:51 AM
MugenPoweredLude
Aug 24, 2003 02:00 PM
tmekjian
Mar 31, 2003 12:19 PM
