Blinking Oil Light
Old Oct 17, 2001 | 05:39 PM
Rain_man's Avatar
New User
Default Blinking Oil Light
Hi, I was driving today and I noticed my oil light started blinking. I pulled over, and checked the dipstick to find it empty. Of course then I added oil and the light doesn't come on, but what would cause my oil to empty out like that? I changed the oil a while ago so I don't think it's due to a loose drain plug or filter.
Any help would be appreciated...
Old Oct 17, 2001 | 05:54 PM
sackdz's Avatar
Default Re: Blinking Oil Light (Ein)
Hard driving.
Old Oct 17, 2001 | 06:36 PM
EG8R's Avatar
Default Re: Blinking Oil Light (sackdz)
What he said. High revving engines do burn oil
http://www.speedvision.com/pub/artic...1/010822a.html
Old Oct 17, 2001 | 09:17 PM
Rain_man's Avatar
New User
Default Re: Blinking Oil Light (mr. skelly)
Only problem is that I don't have a Type-R, just a LS. I post in the ITR forum because alot of knowledgeable people are here so I just need to find out what's wrong.
I have 96k on the car, and I went through 4 quarts in little more than half a year. The only thing that has happned to my car recently is a severe overheating due to a cracked radiator. Could that have damaged some gasket/seals?
Old Oct 17, 2001 | 09:27 PM
B2FiNiTY's Avatar
How many miles did you go through in that half year period?
Old Oct 17, 2001 | 09:46 PM
Rain_man's Avatar
New User
Default Re: Blinking Oil Light (B2FiNiTY)
I'm guessing less than 6 thousand miles or so.
Old Oct 17, 2001 | 09:47 PM
137's Avatar
137
say goodbye to your crankshaft bearings... that motor needs to be rebuilt... ill give it 3 thousand more miles before it ***** itself.
Old Oct 17, 2001 | 09:59 PM
99ITR_SC's Avatar
Default Re: Blinking Oil Light (137)
WOrst case scenario.... give the guy some peace of mind... it might be ok....
Old Oct 17, 2001 | 10:04 PM
137's Avatar
137
Default Re: Blinking Oil Light (99ITR_SC)
sorry i just get so excited... as soon as your oil light turns on you should of turned the light off, that happened to me once in my 84 rex, and i blew a headgasket, scarred a sleeve, fucked up a piston... killed the mains... poor car...
and i had a friend have this happen to his si out of nowhere, and his was fully maint'ed...
Old Oct 18, 2001 | 05:02 PM
Rain_man's Avatar
New User
Just compression tested it with a sears tester.
Got 175 165 175 175. That should be okay right? This is on a LS...
Old Oct 18, 2001 | 05:26 PM
MackSpeed-616's Avatar
just becuase the dipstick is dry doesnt mean the engine is dry of oil... you should add in a quart and then check it.. then use halfs or so until it reads normal.
your comp numbers are fine
Old Oct 18, 2001 | 06:07 PM
Rain_man's Avatar
New User
Default Re: Blinking Oil Light (TurboR616)
Oops I forgot to mention that 2 quarts brought me back up to full. So I went through two quarts in about 6 months... still doesn't sound right at all. I put probally about 5-6k on the car since the last oil change.
Old Oct 18, 2001 | 09:54 PM
tjtruong's Avatar
New User
sounds ok to me!!! Have you tried a high weight oiL or synthetics??
tj
Old Oct 18, 2001 | 10:43 PM
markpaco's Avatar
1 quart every 3K miles is "normal". But you should check it every so often. Once you go low, you are potentially causing serious engine damage.
DCnotTHEshoes
Mar 16, 2008 04:27 PM
EFz6er
Dec 28, 2004 01:39 PM
Rain_man
Oct 21, 2001 08:00 PM
Rain_man
Oct 18, 2001 04:41 PM
