My brothers car
Old Mar 9, 2004 | 01:40 PM
AndyMan2486's Avatar
Default My brothers car
Ok, he has a 1990 honda accord, and its an automatic.. The problem he has been having is that the car wont accelorate in drive, and he has to "drive it standard" shifting it as he drives.. So we did a lil testing and found that he had ECU code 20, which for honda is ELD problems.. which says "electrical load detector circuit problem" So today, I went out and looked at the car, and noticed that the radiator wire wasn't plugged into anything, and that there was another wire near it, that apears to be striped of the cap. So what I am wondering, is if you think all these problems could be caused by this wire not being plugged in? or if you have any other ideas, let me know! thanks alot!
Old Mar 9, 2004 | 01:42 PM
fw190bvi's Avatar
Default Re: My brothers car (AndyMan2486)
well......trial and error.....plug it in and see if it works......but i kinda doubt thats the culprit
Old Mar 9, 2004 | 01:44 PM
Default Re: My brothers car (fw190bvi)
well problem is its just a wire, no connector..
Old Mar 9, 2004 | 01:46 PM
fw190bvi's Avatar
i dun know too muc about older gen accords.....but since it was just going into the radiator, i kinda doubt thats the code ud be throwin, but like i said, i dun know too mcuh.......id get the right connector from ur honda dealership first.......regardless if thats the problem, u should fix taht anyway
Old Mar 9, 2004 | 02:51 PM
are these signs of any major problem? You can not move the car unless you put it in first, and shift your way up.. and it is automatic..
Old Mar 9, 2004 | 07:25 PM
John Gordon's Avatar
OK maybe I can help. I have a '90 Accord with an automatic transaxle. I just happen to have taken the entire main fan housing out because I'm replacing the fan motor (started howling). Its no problem in the winter because the car runs cool enough that the fan rarely turns on. So, while the fan is out those "radiator wires" are hanging free, maybe just like yours. In my case this is not generating any codes or causing any problem at all. I don't know of any other "radiator wires" except maybe the A/C fan.
Old Mar 9, 2004 | 08:42 PM
gray_ghost91's Avatar
im not familar with honda engines or trannies but i had that same problem with my hyundai excell (hold your jokes and laughs until the end of the thread please) and it turned out to be the throttle valve cable to the tranny had come undone from the carb ( webber redline)...
regnevazota
Sep 21, 2022 06:53 AM
Chickenfcker
Dec 27, 2014 07:24 PM
santii7
Jun 21, 2011 07:22 AM
fergs96integra
Audio / Security / Video
23
May 22, 2006 09:17 AM
EJK
Apr 24, 2002 01:58 PM
