ls ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAG lll INTEGRA »</TD></TR><TR><TD CLASS="quote">ones a 99 ones a 00..
other than that nada</TD></TR></TABLE>
so a smog ref wouldn't be able to tell it was really a 99 ecu being used on a 00 engine?
other than that nada</TD></TR></TABLE>so a smog ref wouldn't be able to tell it was really a 99 ecu being used on a 00 engine?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAG lll INTEGRA »</TD></TR><TR><TD CLASS="quote">not at all</TD></TR></TABLE>
thanks.
can anybody else vouch for that?
thanks.
The actual componentry inside will be the same. There are no differences between those years IF it's from the same type of car (i.e.: automatic to automatic, 5-speed to 5-speed, etc).
If they were **** enough, they could probably trace the serial numbers on the ECU cover down to the exact year, but I doubt they would do that. A simple VIN number check would tell you from the motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris y0! »</TD></TR><TR><TD CLASS="quote">
so a smog ref wouldn't be able to tell it was really a 99 ecu being used on a 00 engine?</TD></TR></TABLE>
99 ecu is obd2.1 while 00 ecu is obd2.2
i've been told that a smog ref might plug in a OBD device via the service connector but i dont know if that is right..if they do, it might show the differences.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nolex7 »</TD></TR><TR><TD CLASS="quote">
99 ecu is obd2.1 while 00 ecu is obd2.2 </TD></TR></TABLE>
Hmm, is it really? I didn't know that.
i thought 96-98 was obd2.1 and 99-01 was obd2.2?
</TD></TR></TABLE>i thought 96-98 was obd2.1 and 99-01 was obd2.2?
i thought 96-98 was obd2.1 and 99-01 was obd2.2?</TD></TR></TABLE>
for gen 3 integras, 94-95 is obd1, 96-99 is obd2.1 and 00-01 is obd2.2
00-01 is also when integras came with the key immobilizer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nolex7 »</TD></TR><TR><TD CLASS="quote">00-01 is also when integras came with the key immobilizer.</TD></TR></TABLE>
thats why i made this post. to swap an engine into a civic legally, it has to be the same year or newer, ecu must be the same year as the motor, and the ecu must not have any cels and needs to be able to throw codes.
i can't use an '00 ecu because if i take out the immobilizer, the ecu will throw a code.
and now apparently i can't use a '99 ecu because there is a way to tell its not a '00.
time to kill myself... smog time is coming up too
any suggestions
any suggestions
trust me i dont think there gonna know ur useing a 99 ecu... most just hook up to the ecu port and test thats all, and if all else fells theres illeagle places taht will pass u
The way I tell if an ecu is obd2A or obd2B is look at the plugs..... 92-95 civics and integras are obd 1, 96-98 civic/96-99 integra's are obd2 A, and 99-01 civic/00-01 integras are obd2B. If you have an obd2A ecu, it will have a gap inbetween the middle of the ecu. If its an obd2B ecu, it will have a gap/space on the left of the plugs....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grizzly Adams »</TD></TR><TR><TD CLASS="quote">Why would the ECU throw a code if you have the immobilizer removed?</TD></TR></TABLE>
i think it throws "internal ECU failure"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris y0! »</TD></TR><TR><TD CLASS="quote">i think it throws "internal ECU failure"</TD></TR></TABLE>
I'm not sure. I know of a couple of ITR swaps running around with original ECU's that were chipped and reprogrammed to eliminate the immobilizer. None of them throw codes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grizzly Adams »</TD></TR><TR><TD CLASS="quote">I'm not sure. I know of a couple of ITR swaps running around with original ECU's that were chipped and reprogrammed to eliminate the immobilizer. None of them throw codes.</TD></TR></TABLE>
eliminating the immobilizer on g3 ecus doesn't involve chipping or reprogramming.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris y0! »</TD></TR><TR><TD CLASS="quote">eliminating the immobilizer on g3 ecus doesn't involve chipping or reprogramming.</TD></TR></TABLE>
I should have been more clear. They are both equipped with chipped/reprogrammed ECU's that have had the immobilizer removed, and neither ECU throws a code.
