problem obd1 dist
Old Mar 8, 2004 | 07:06 PM
wykidrex's Avatar
Default problem obd1 dist
i want to know if i can rewire my obd1 gsr distributor so that it will work on my obdo b16a.Give me some info on that thanks.
Old Mar 8, 2004 | 07:09 PM
Maddox's Avatar
Yea you can..
You can either change the plugs on the dist or change the plugs on the harness..
I just changed it on the dist.. I didnt want to hack my harness up.. You can do a search and you can get all the info on color match... Good Luck
Old Mar 8, 2004 | 07:11 PM
krazie1's Avatar
BANNED
Default Re: (AllMotorCRX161)
yep that is the same process I am debating on right now
but for sure going full OBD1 now
no more owrries about fuel curves and wack hp gains
just smooth rpms all the way through the dyno sheet
just my opinion
but it is up to u if u can get those clips
or find them
Old Mar 8, 2004 | 07:31 PM
Colin's Avatar
Default Re: problem obd1 dist (wykidrex)
it'll work if the car is running obd1. but if you're running obd0 the obd1 dist will not work.
Old Mar 8, 2004 | 08:22 PM
Redline130's Avatar
Default Re: problem obd1 dist (91IntegGS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91IntegGS &raquo;</TD></TR><TR><TD CLASS="quote">it'll work if the car is running obd1. but if you're running obd0 the obd1 dist will not work. </TD></TR></TABLE>
You need to use the corresponding ecu to the distributor that you are using.
HondaRexBoi
Apr 20, 2021 11:52 PM
ryanangelo212
Mar 18, 2013 12:23 AM
DieMaster
Apr 2, 2006 05:09 PM
chirp2hrd
May 2, 2003 04:26 PM
skud_dusty
13
Apr 25, 2003 11:51 PM
