skunks stage 2's... ive searched....
Old Mar 8, 2004 | 07:06 PM
genetsang's Avatar
Default skunks stage 2's... ive searched....
i know this have been covered a billion times before. ive searched but did not find the info that i am looking for.
i need someone with decent knowledge about them in a gsr....
i know in order to utilize stage 2's full potential, it needs high compression, better flowing head. and all the basics (i/h/e/cam gears/valvesprings,vafc......)
has anyone used them with a stock gsr compression and stock gsr IM?
any other insight is appreciated
Modified by genetsang at 11:37 PM 3/8/2004
Old Mar 8, 2004 | 07:38 PM
Heisdan's Avatar
bump
Old Mar 8, 2004 | 09:06 PM
radio1global's Avatar
Not to be an *** but I was thinking of the same thing earlier and its just this simple you said it your self. For the full potential you need the essentials as you mentioned so with stock compression and stock IM the cams wont be at full potential im sure you will feel a diff but not much.
Old Mar 8, 2004 | 11:15 PM
DC2*Integra's Avatar
Default Re: skunks stage 2's... ive searched.... (genetsang)
with stock compression, you are going to get better results with the stage 1.
Old Mar 9, 2004 | 03:37 AM
ebelp's Avatar
Default Re: skunks stage 2's... ive searched.... (DC2*Integra)
I have a friend who is running the stage 2's with the stock compression, and the stock IM. To my knowledge, he's had no problems with it at all. He only uses a VAFC with the setup.
Old Mar 9, 2004 | 04:48 AM
DocIowa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2*Integra &raquo;</TD></TR><TR><TD CLASS="quote">with stock compression, you are going to get better results with the stage 1. </TD></TR></TABLE>
True.
If your going to use stage 2's. pop the head off and raise the compression a bit.
Old Mar 9, 2004 | 11:51 AM
genetsang's Avatar
Default Re: skunks stage 2's... ive searched.... (DocIowa)
is there positive proof that, while running stock compression and stock intake manifold in a c1, the gains will roughly be the same as using stage 1's?
head will be removed and a thinner head gasket might be used.
please.. i need some insight from someone who used or currenntly using this setup to back it up, thanks.
Old Mar 9, 2004 | 11:57 AM
xx dc2teg xx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by genetsang &raquo;</TD></TR><TR><TD CLASS="quote">is there positive proof that, while running stock compression and stock intake manifold in a c1, the gains will roughly be the same as using stage 1's?
please.. i need some insight from someone who used or currenntly using this setup to back it up, thanks.</TD></TR></TABLE>
yes running stage 2's on a basically stock gsr motor will net about the same gains with a stage 1 if not LESS.
YOu would be "overcamming" basically. So i would stick with a less milder cam.
Old Mar 9, 2004 | 12:26 PM
genetsang's Avatar
Default Re: skunks stage 2's... ive searched.... (xx dc2teg xx)
true.
Mhollaek9
20
Aug 17, 2007 01:08 PM
skata89
May 28, 2007 09:10 AM
tachyteg
Mar 1, 2004 11:41 AM
gsrvx
23
Sep 13, 2003 08:18 AM
Tuney
Jan 21, 2003 09:16 AM
