went to the track, 11.69@115.62mph
Old Mar 8, 2004 | 06:36 PM
ek9turbo's Avatar
Default went to the track, 11.69@115.62mph
first time at the track after i retuned, setup is:
ls vtec, type r head
victor x intake manifold
9:1 cr je pistons, eagle rods
550 cc injectors
hondata
drag kit
54trim, 63 ar
its a 96 civic, weight in at 2460 with me in it
at 14psi we made 348hp and 241ft-lb , injectors were running at %100 duty cycle past 8000 so there were we had to stop, total timing was 19
ok so we went to the track and here is the result
reaction 0.446
60 ft 1.7312
1/8 et 7.5027
1/8 mph 94.52
1/4 et 11.698
1/4 mph 115.62
time was done using 22x8x15 MT slicks car was hitting rev limiter through all first gear, i think i shifted early to second cause rpm dropped down to like 5900.
car felt good untill i shifted to 4th and 5th then i had to shift early cause car felt funny past 7800, just to mention car ran 12.1 at 118.25mph with only 280 hp
car was dead empty on gas when we ran so it could be fuel starvation that caused the low mph, put more fuel but broke axles off line on the second run
so let me know what u guys think
thanks
Modified by ek9turbo at 3:48 AM 3/9/2004
Old Mar 8, 2004 | 06:43 PM
Kataku2K3's Avatar
Default Re: went to the track, 11.69@115.62mph (ek9turbo)
Sounds good What size slicks are you running and you are working with an '96-2000 Civic hatch chassis, right? Eliminate that last shift and you should get your ET down and your mph up a bit more. Lane runs consistent 11.50's in the 125mph range in his 2600lbs. EJ6 on 12lbs. with a very similar setup so I have no doubts that you'll get it down more. Good Luck
DrkGreenAccord's Avatar
wow nice The trap speed is low, what were you running to help you traction wise, if you don't mind?
Good Job
Old Mar 8, 2004 | 06:49 PM
91tegrals's Avatar
damn nice #s
Old Mar 8, 2004 | 06:50 PM
ek9turbo's Avatar
Default Re: went to the track, 11.69@115.62mph (Kataku2K3)
96 civic hatch back, 2240lb w/o driver 2460 with me in it
22x8x15 MT slicks
Old Mar 8, 2004 | 06:52 PM
TABIAS's Avatar
I want to be MADE into Ice-T
Default Re: went to the track, 11.69@115.62mph (DrkGreenAccord)
nice numbers
Old Mar 8, 2004 | 07:23 PM
blown_LS's Avatar
That's nice man, also pretty good 60' time.
Old Mar 8, 2004 | 07:31 PM
CRXRageD's Avatar
that's pretty damn quick. Nice et.
Old Mar 8, 2004 | 09:37 PM
turtle-eg's Avatar
Are you running a stock fuel pump and fuel regulator? Props to you, you have ***** to run at 100% duty cycle!!! Anyways, good times!
Old Mar 8, 2004 | 10:09 PM
Reilly's Avatar
Nice times!
Old Mar 8, 2004 | 11:29 PM
DLB1994's Avatar
Default Re: went to the track, 11.69@115.62mph (turtle-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtle-eg &raquo;</TD></TR><TR><TD CLASS="quote">Are you running a stock fuel pump and fuel regulator? Props to you, you have ***** to run at 100% duty cycle!!! Anyways, good times!</TD></TR></TABLE>
its a stock reg with the holley 255 fuel pump
Old Mar 9, 2004 | 03:26 AM
B17AGSR's Avatar
Default Re: went to the track, 11.69@115.62mph (DLB1994)
Get bigger injectors....good times bro
Old Mar 9, 2004 | 03:59 AM
B17aTrbo's Avatar
New User
Nice times! Va?
Old Mar 9, 2004 | 05:29 AM
DLB1994's Avatar
Default Re: went to the track, 11.69@115.62mph (B17aTrbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B17aTrbo &raquo;</TD></TR><TR><TD CLASS="quote">Nice times! Va?</TD></TR></TABLE>
yeh we was at richmond dragway sunday
Old Mar 9, 2004 | 06:32 AM
B17aTrbo's Avatar
New User
Even more impressed cuz that's a rather shitty track unless they hooked it up this year...
Was gonna go sunday but couldn't get my lazy *** outta bed
Old Mar 9, 2004 | 07:20 AM
SOHC_MShue's Avatar
yes this is one badass car .
Old Mar 9, 2004 | 08:27 AM
Rod.'s Avatar
Default Re: went to the track, 11.69@115.62mph (SOHC_MShue)
is it a gutted ek? I hope I can get times like that once my lsvtec is up and running. Can we get some pics?
Old Mar 9, 2004 | 08:55 AM
Sinitron's Avatar
Default Re: went to the track, 11.69@115.62mph (redturbocivic)
Fast times!
Yeah, is that a full interior or race-ready car?
Old Mar 9, 2004 | 12:29 PM
ek9turbo's Avatar
Default Re: went to the track, 11.69@115.62mph (Sinitron)
only front seats in the car, about to put a roll cage in there, going back next weekend hopefully we ll do better time and mph with bigger slicks and more fuel in the gas tank
Old Mar 9, 2004 | 12:33 PM
ek9turbo's Avatar
cars weight is 2240lb, so its 20lb heavier than stock cx
Old Mar 9, 2004 | 01:23 PM
J.R.'s Avatar
nice numbers
Old Mar 9, 2004 | 02:00 PM
RobbieG35's Avatar
12 Years Strong
Default Re: went to the track, 11.69@115.62mph (J.R.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J.R. &raquo;</TD></TR><TR><TD CLASS="quote">nice numbers </TD></TR></TABLE>
Very nice,
Old Mar 9, 2004 | 02:10 PM
Kelly.'s Avatar
I've quit using this account
Default Re: went to the track, 11.69@115.62mph (blown_LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blown_LS &raquo;</TD></TR><TR><TD CLASS="quote">That's nice man, also pretty good 60' time. </TD></TR></TABLE>
open diff?
if so then thats pretty good.
either way, good work, keep it up
Old Mar 9, 2004 | 02:48 PM
Turbo E's Avatar
fast.
Old Mar 9, 2004 | 02:49 PM
ek9turbo's Avatar
Default Re: went to the track, 11.69@115.62mph (llewsirc)
type r tranny (lsd for sure)
thanks everyone for ur comments, more to come ill post new times next week
