What is this? 90 Integra trunk vent?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intgrboy »</TD></TR><TR><TD CLASS="quote">that allows your trunk to close easier (allowing air to escape)... why do you want to remove it?</TD></TR></TABLE>
Yep,.it is actually for all the doors...if you we're to see it wen you close a door...it flaps open to help them close smoother....although...Teg Doors sound like **** when you close em...wish it helped that!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by martik »</TD></TR><TR><TD CLASS="quote">Leaking water into trunk when it rains</TD></TR></TABLE>
that could be your taillight gaskets.
it was in my case.
it was in my case.
most likely that has nothing to do with your leak.... there isn't really a good way for water to get from the outside to the inside thru that went.
Check your taillight gaskets. Also, does your car have a sunroof? If so check the sunroof drain tube. Its on the side of the car that you already removed the panel to get access to that vent. Just move forward and up the c-pillar and check along the tube to make sure it didn't become disconnected somewhere.
The seal around the vent is leaking a cup of water into the trunk after each rainfall, so I'm going to re-seal it with silicone. Water enters thru the gap between the bumber and body panel. The tail-light gaskets and sunroof drain tubes were also leaking which I already repaired.
pinecone
Apr 22, 2006 05:30 PM
b16pwrdeg
18
May 9, 2005 02:29 PM
