Greddy turbo kit for rsx?
Old Mar 8, 2004 | 01:01 PM
GoFastHappy's Avatar
Default Greddy turbo kit for rsx?
hey guys, with a 2003 acura rsx-s, is the greddy turbo kit at 7 psi a good idea for hp? Would you also recomend the intercooler kit from greddy? Has anyone else done this and have dyno tests? Also, if this isn't the best bang for the buck on this car, what other turbos would you recomend or other modifications. Oh yeah, if i got a turbo, at what psi would i have to start changing the internals or the compression ratio. thanks in advance
Old Mar 8, 2004 | 02:55 PM
CHILIBEANZ's Avatar
no complaints here. i had one of the first batch kits and had problems in the beginning. answers to your questions depend on how much power u want. i've had my greddy kit 7psi for almost a year. no problems. if u want bigger power go cybernation.
Old Mar 9, 2004 | 09:52 PM
RsxVengeance's Avatar
clubrsx has tons of informations on the Greddy kit. check them out....
Old Mar 10, 2004 | 08:47 PM
jdmandy's Avatar
Default Re: (RsxVengeance)
CYBERNATION all the way for the big nubers. i heard that they lowerd all the prices by a grand
Old Mar 15, 2004 | 08:03 PM
lil888chink's Avatar
Id go with cybernation. But a lot of ppl have good running greddy kits. They jus need to be wired properly when installing
Old Mar 15, 2004 | 09:26 PM
ZTYPE_S's Avatar
Default Re: Greddy turbo kit for rsx? (GoFastHappy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoFastHappy &raquo;</TD></TR><TR><TD CLASS="quote">hey guys, with a 2003 acura rsx-s, is the greddy turbo kit at 7 psi a good idea for hp? Would you also recomend the intercooler kit from greddy? Has anyone else done this and have dyno tests? Also, if this isn't the best bang for the buck on this car, what other turbos would you recomend or other modifications. Oh yeah, if i got a turbo, at what psi would i have to start changing the internals or the compression ratio. thanks in advance</TD></TR></TABLE> Yes, a greddy turbo kit is a very good idea for hp...and yes I would recomend a greddy intercooler. its best if you go w/ the intercooler.With that turbo kit you would get 243hp at 7,400rpm, and 175lb-ft. at 6100rpm. stock is 172hp, and 124lb-ft. so youre getting gains of 71hp and 51lb-ft.
Old Mar 16, 2004 | 04:02 PM
alright, thanks for the tips, i will also check out cybernation
Old Mar 17, 2004 | 08:50 AM
redliner8000's Avatar
Default Re: (p220)
i was just wondering, should you get any engine work done before you get the turbo. i just want to make sure i don't blow my engine.
Old Mar 17, 2004 | 11:43 AM
if you don't plan to boost 10psi everyday then no.
Old Mar 17, 2004 | 01:44 PM
if you did, then what should you do? also, the cybernation isn't smog legal and i need it to pass emissions when i have to. any suggestions? and is the greddy smog legal?
nighthawkgsr
Sep 27, 2006 01:18 PM
xQwertyx
Mar 29, 2006 06:07 AM
99integsr
Dec 26, 2005 09:04 PM
-BlueGSR-
Apr 24, 2003 09:52 AM
George H
May 4, 2002 09:13 AM
