Look what I did :(
Broke the top of this rod off on my vavle cover. (h23)
Is there anything I should do about it at the moment? I figure i'll be fine since i have the 4 corners snuggin it down still.
Sucks. Where you using a torque wrench? Looks like you went a bit to far. I would find a way to patch that up till you get a new one, use some liquid gasket or some high temp tape or something? A little Oil might start comming out. Also i would keep my eye on the sparkplug chambers and make sure no oil goes in em.
did that about 4 time on 4 different bolts while doing my head gasket on my legend. You have to take off the vavle cover and unscrew the stud. Go to a dealership they'll give you a new one for about 5 dollars.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Sport »</TD></TR><TR><TD CLASS="quote">hahaha...I did the same thing on my old h23a1. replaced it with a JDM h22a. Problem sovled.
Gotta justify gettin a new motor somehow!
Just go to a parts store, get two open-ended nuts to fit on that stud, screw them both onto the stud, and start undoing it w/ the bottom nut. The top nut will lock it in place, bringing up the stud. Then slap in a new stud, and only tighten it down lightly next time!
</TD></TR></TABLE>Gotta justify gettin a new motor somehow!
i've done this twice so far, both times with a torque wrench. after it broke i ordered the new stud online (cheaper) and used hi temp rtv to seal the hole. it worked but be sure to check the rtv periodically, if the seal fails it can make a nice little mess.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD »</TD></TR><TR><TD CLASS="quote">That is actually a common thing to do; Over tightening the bolts.
we havew all been there
</TD></TR></TABLE> we havew all been there
91crx-jace
Apr 22, 2012 04:36 PM
216.226.142.95:27016
Apr 27, 2004 03:51 AM
