CTR pistons in b16a2???
Ive been searching around and yet to have good reliable input in on this. some people say that the CTR pistons will yeild a lower C/R than the A2 pistons. Plan on using some eagle rods. will the rods have to be modified in any way to make the pistons fit?
Also head that will be used is a JDM ITR Head. with 01 ITR cams. will there be any clearance issues with the valves?
just keep in mind two things...
1- ctr pistons will sit above the deck in a b16. that's no bueno.
2- you'll need to get the pistons fitted for circlips if you plan on using eagle rods, because factory honda pistons/rods are press fit, and aftermarket rods like eagle utilize a free-floating wrist pin.
tvrsir
Dec 7, 2003 10:39 AM
eddiecut
Aug 5, 2003 08:58 AM
euclid
May 27, 2003 03:39 PM
