Wiring for a JDM B16 (XSi) in a 91 Integra Ls
Old Mar 8, 2004 | 12:31 PM
JzDcM's Avatar
Default Wiring for a JDM B16 (XSi) in a 91 Integra Ls
I have a front clip and have all of the wiring harness for the integra Xsi with the b16. I swapped the motor into a 91 ls that was wired for a GSR motor. Most of the plugs are the same except for one in between the other two plugs on the passengers side on the chassis harness. The plug on the body is rectangular with 6 wires and the motor plug is round with 8 wires. let me know what to do. thanks guys
Old Mar 8, 2004 | 01:19 PM
silver00teg's Avatar
Default Re: Wiring for a JDM B16 (XSi) in a 91 Integra Ls (JzDcM)
you can use the factory harness and just add the wires for vtec: knock sensor, vtec pressure that would be the easy way i think
Old Mar 8, 2004 | 01:28 PM
JzDcM's Avatar
the exisiting wiring in the body is the obd1 wirng for the GSR so they don't match but what is the easiest way to get it right
Old Mar 8, 2004 | 01:41 PM
Default Re: (JzDcM)
im not sure about that i would say try to find a factory non obd harness for your car
Old Mar 8, 2004 | 02:56 PM
JzDcM's Avatar
man thanks but there has got to be a way
Old Mar 8, 2004 | 03:54 PM
BACKintheDA's Avatar
Default Re: (JzDcM)
Haha, I am in the same situation as you. 92-93 OBD1 b16a motors into OBD0 91 Integras. I believe you can either use an obd0 distributor and ECU, or use your existing parts but get the obd0 to obd1 conversion harness. Also, this thread might answer some questions: https://honda-tech.com/zerothread?id=770001
white_DB1
Jun 11, 2009 03:30 PM
FIGARILA
Feb 4, 2009 11:07 AM
haccord550
Jun 5, 2005 04:57 AM
onekoop
Dec 5, 2004 03:26 PM
JzDcM
Mar 8, 2004 12:16 PM
