ITR intake manifold vs. Skunk2 IM w/turbo setup
Hi, all, I know there are alot of ITR IM and Skunk2 IM answers out there, but i haven't ran across one with a turbo setup. Which one will be better with turbo setup that will be running 8 psi on an LS motor w/I/E? Will it even work with the ITR butterfly openings?
Thanks all
Thanks all
They are very similar manifolds, and neither are dual stage.
I would say you may as well go Skunk2 if youre choosing between the 2 with a turbo setup.
No, No....... I am wondering which one is better using a turbo setup. BC the ITR IM has a butterfly opening that opens when it's running high RPMs, but wasn't sure what happens or if is good at all when it's running low RPM (LS motor) and boost........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foxfai »</TD></TR><TR><TD CLASS="quote">How does GSR IM have a butterfly?? I don't think they have one except the type-R</TD></TR></TABLE>
you sir should learn more about honda motors before you go turbo.. just my opinion though
gsr has one.... type R does not...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyoter91 »</TD></TR><TR><TD CLASS="quote">you sir should learn more about honda motors before you go turbo.. just my opinion though
gsr has one.... type R does not... </TD></TR></TABLE>
Exactly. Anyone who has informed you otherwise doesn't know what they're talking about.
reg_lus
May 24, 2014 04:48 PM
JDubya
Dec 12, 2003 11:46 AM
