Spark Plugs
You should run the NGK plug recommended under the hood
NGK 5F-11 or something like that it is Heat Range 5 already and thats hot .. it would be the best plug for you, unless you want the longevity of platnium or runing nitrous
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Creep »</TD></TR><TR><TD CLASS="quote">NGK copper</TD></TR></TABLE>
i second this.
i second this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraBoy04 »</TD></TR><TR><TD CLASS="quote">So the platinum lasts a long time?</TD></TR></TABLE>
yes.. regular NGK plugs i think are suppose to be replaced every 15k and Platnium is like 50k or 60k
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraBoy04 »</TD></TR><TR><TD CLASS="quote">So just go with the NGK?</TD></TR></TABLE>
YOU CANT EVER GO WRONG WITH oem
I don't think AutoZone stocks NGK plugs.
Just go to your dealer, they'll have them in stock, or try http://www.sparkplugs.com.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheGSRGuy »</TD></TR><TR><TD CLASS="quote">I don't think AutoZone stocks NGK plugs.
Just go to your dealer, they'll have them in stock, or try http://www.sparkplugs.com.</TD></TR></TABLE>
no they dont, i dont think none of them do.. check out advance discount auto or if your in the northeastern area, strauss
So, O reilys, advance auto parts, or autozone dont carry them?
http://www.sparkplugs.com/resu...82857
Which plug on here is the right one?
You can get NGKs here in FL at discount auto however, they arn't that expensive from the dealer. I work for Nissan and plugs still are pretty cheap unless you go for platnum.
LOSERboy
13
Aug 13, 2004 10:56 AM
