Question about 4th gen front / rear knuckles & ball joints
As you probablly know, when a lower ball joint became worn, our friends from honda try to sell a whole knuckle. The ball joint does not exist as a separate part (as it was in 3rd generation of prelude).
The price of whole knuckle kills... However there is a simple and much cheaper solution: the ball joint can be easily extracted (idem as 3rd gen), and you just use a ball joint from 1987-1990 (about) honda legend. The dimensions of a legend ball joint are identical.
My question is about rear knuckles: is the ball joint the same as a front one? Visually it is. Has someone done an exchange?
I have also changed the front lower ball joint, the Legend's one is exactly the same. I am also wondering about the rear one and the UPPER ones. Can these be changed too?
The upper ones does not seem to be interchangeable with legend. I haven't looked exactly, but they seem to be soldered with arm.
The question about rear lower ball joints remains unanswered...
In my opinion you should press them: a hammer is not a good tool, you would risk to deformate the joint.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wstef »</TD></TR><TR><TD CLASS="quote">The upper ones does not seem to be interchangeable with legend. I haven't looked exactly, but they seem to be soldered with arm.
Even the upper ones can be pressed out - I changed them with some from other Prelude upper arm. But I don't know anything about replacement.
