What else swaps in besides a H22?
Old Mar 7, 2004 | 09:11 PM
1990hondaHF's Avatar
Default What else swaps in besides a H22?
I've been doing a bit of searching and am trying to find something that swaps into a 98 Accord in place of the f23a1....I did find that a f20b..180HP would bolt in...I think...? But they are close the price of the H22....what else can I look for?
Old Mar 7, 2004 | 09:24 PM
cd555's Avatar
Default Re: What else swaps in besides a H22? (1990hondaHF)
Anything you want! Just as long as you got enough money.
Old Mar 7, 2004 | 09:47 PM
Monkey Fing a Coconut's Avatar
Default Re: What else swaps in besides a H22? (farroutt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by farroutt &raquo;</TD></TR><TR><TD CLASS="quote">Anything you want! Just as long as you got enough money. </TD></TR></TABLE>
u have been so helpful
Old Mar 7, 2004 | 10:02 PM
cd555's Avatar
Default Re: What else swaps in besides a H22? (twistedbydezign)
Thanks I try
Old Mar 8, 2004 | 06:27 AM
v4lu3s's Avatar
RTFM
any engine eyou uwant will fit if youo have t teh money to pay for it and install.
easiest to fit are f and h series engines from honda
Old Mar 8, 2004 | 06:44 AM
KGAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990hondaHF &raquo;</TD></TR><TR><TD CLASS="quote">I've been doing a bit of searching and am trying to find something that swaps into a 98 Accord in place of the f23a1....I did find that a f20b..180HP would bolt in...I think...? But they are close the price of the H22....what else can I look for?</TD></TR></TABLE>
is the f23a1 blown?? i would turbo it if it's in good shape. a legal 6th gen swap is going to cost alot since you would need a 98-01 USDM H22.
Old Mar 8, 2004 | 06:50 AM
ForceThis!'s Avatar
isuzu v6
Old Mar 8, 2004 | 07:07 AM
TypeRKoncepts's Avatar
i'm just waiting on sumone to drop a fwd sr20det into a honda.
Old Mar 8, 2004 | 08:00 AM
Default Re: What else swaps in besides a H22? (KGAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KGAccord &raquo;</TD></TR><TR><TD CLASS="quote">
is the f23a1 blown?? i would turbo it if it's in good shape. a legal 6th gen swap is going to cost alot since you would need a 98-01 USDM H22.</TD></TR></TABLE>
No, it runs fine....I just like swaping engines....Turbo might not be a bad idea. I'm not quite sure why I didn't consider it. I think in the long run it would be cheaper too. I've done a bit more searching and came up with a few engines that I THINK will fit:
H22a
F20b
F20c
H23
and someone emailed me that there is a JDM f23....I'm going to call him later for more info on that one....I also read that ay "H" will bolt up to and "F" tranny. That could save a few bucks!
Old Mar 8, 2004 | 08:35 AM
v4lu3s's Avatar
RTFM
thte f20c spins the wrong way, its basically a k series engine.
Old Mar 8, 2004 | 08:39 AM
Slammed95Cord's Avatar
Default Re: (v4lu3s)
the f series tranny will bolt up but your h22 will run so bad you will be like wow im gay for doing that. the gear ratios are so different
Old Mar 8, 2004 | 10:32 AM
KGAccord's Avatar
H22a
F20b
F20c
H23
and someone emailed me that there is a JDM f23....I'm going to call him later for more info on that one....I also read that ay "H" will bolt up to and "F" tranny. That could save a few bucks!</TD></TR></TABLE>
if your going all-motor then you want an H22. the f20b has same hp as the h22, but less trq and a 6th gen is heavier than the 90-97 accords so you need al the torque you can get.
Old Mar 8, 2004 | 12:18 PM
If I was going to swap, I would like to spend the least amount of $$$ I could. I'm NOT looking to run in the 10's or 11's, I just miss having grease underneath my fingernails...so at first, I'd like to go with a longbloch, then look for a tranny. By the way, it's an auto....if that makes a difference in helping me choose an engine..Thanks.
Modified by 1990hondaHF at 12:17 AM 3/9/2004
Old Mar 8, 2004 | 02:23 PM
Atheist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990hondaHF &raquo;</TD></TR><TR><TD CLASS="quote">If I was going to swap, I would like to spend the least amount of $$$ I could. I'm looking to run in the 10's or 11's, I just miss having grease underneath my fingernails...so at first, I'd like to go with a longbloch, then look for a tranny. By the way, it's an auto....if that makes a difference in helping me choose an engine..Thanks.</TD></TR></TABLE>
10's? It will cost a **** load of money to run 10s man, I hope your commited.
Old Mar 8, 2004 | 03:18 PM
The_Todd's Avatar
Farts in the shower
Default Re: What else swaps in besides a H22? (Atheist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Atheist &raquo;</TD></TR><TR><TD CLASS="quote">
10's? It will cost a **** load of money to run 10s man, I hope your commited.</TD></TR></TABLE>
If its all motor yes 10's will cost a lot, if its blown....shouldn't be a huge problem. Good luck and post them pics and keep us updated .
Old Mar 8, 2004 | 05:15 PM
dd_biggy's Avatar
If you are going to swap the engine, swap the tranny also. Like someone said earlier, the gear ratios will be all diff., to build an auto up can cost much more than a good manual. Manuals are more fun anyways, right? Also, 10s and 11s could be next to impossible to run w/ a stock automatic, you would grind it out before you put your power to the ground, which I understand isn't a good thing.
Old Mar 8, 2004 | 05:41 PM
accord387's Avatar
Not to sound like a dick... but your talking about doing things the least expensive to run 10s. You might want to look at your car again and then think about the 1000s ontop of 1000s of dollars it would take for it to see 10s... i mean even in a lil civic it takes a good amount of money to hit 10s.
Old Mar 8, 2004 | 05:58 PM
Bantam's Avatar
2nd Coolest Person in DFW
uhh, I dont think that the 10 second 1/4 mile times will be in your future unless you have a dedicated drag car (not saying that it cant be done, but im saying that you doesnt sound like the most likely person to do it)...10 sec FWD and reliable isnt cheap...especially not without it being stripped
Old Mar 8, 2004 | 06:03 PM
Taiyed's Avatar
F20c is the s200 motor...probably won't bolt up to a fwd tranny of any sort...feel free to correct me if I'm off base here...
Old Mar 8, 2004 | 06:07 PM
The_Todd's Avatar
Farts in the shower
Default Re: (Taiyed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Taiyed &raquo;</TD></TR><TR><TD CLASS="quote">F20c is the s200 motor...probably won't bolt up to a fwd tranny of any sort...feel free to correct me if I'm off base here...</TD></TR></TABLE>
Right the f20C is for the s2k...but how did that come up? and whats an s200?
He was reffering to the f20B which is a 2.0L dohc vtec 92+accord siR.
I would swap for the h23 and boost it. The f22's are very well built blocks (damn near indestructable).
Old Mar 8, 2004 | 06:10 PM
Taiyed's Avatar
Default Re: (VRDrvr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr &raquo;</TD></TR><TR><TD CLASS="quote">
I would swap for the h23 and boost it. The f22's are very well built blocks (damn near indestructable).</TD></TR></TABLE>
look in one of the first posts...f20c is one of the engines mentioned...
*bullshit on* yeah...s200...it's a 3 beater...like a convertible RWD geo metro... *bullshit off*
Old Mar 8, 2004 | 08:15 PM
EDIT! EDIT! I did not mean to say I wanted to run 10's or 11's....MISPRINT! I wanted to say "I DON"T want to run 10's or 11's" sometimes my fingers can't keep up with my brain and I skip words I meant to type. Bottom line is that I just want to do a swap. I find it hard to drive around in an stock car. You all are members so you know what I mean. Sorry if I said I wanted to run 10's in an Accord.....from now on I'm going to proof-read threads before I hit "post"
Old Mar 8, 2004 | 08:26 PM
-RedneckDave-'s Avatar
Working
Default Re: (1990hondaHF)
If you just want to do a swap then i would say go with an H22 and keep it reliable. It would be a lot easier to pass emissions in your state with that rather than a turbo if you have to get it tested.
Old Mar 8, 2004 | 08:35 PM
Default Re: (01accordv6)
That is the nice thing about Florida...we don't have checks here...yet. H22 would be a nice upgrade....would power steering and A/C items bolt up or would I need Hasport items?
Old Mar 9, 2004 | 01:45 AM
Working
Everything can be hooked up you just have to search in the archived threads and find the ones you need cause this has been covered a few times. here are a few i found: https://honda-tech.com/zerothread?id=614434
https://honda-tech.com/zerothread?id=527685
https://honda-tech.com/zerothread?id=266886
Hope that helps
