P28 reprogramed to type R spec for a B18C
i was thinking of getting a P28 ECU that was reprogramed to type R specs for my GSr B18C motor...it is basically stock motor except for a header...i have jsut begun working on this motor...my question is will i feel any difference with this ecu versus the P72 gsr ecu...thanks for any help...
it depends who does it and what programs get used ... if I did it for you, yes you will because I get a lil more aggressive on the ignition timing curve. Honda was very conservative on the stock timing curves, I'm not.
Greg
Greg
Hey greg im from woodbridge too, I drive a 01 black gsr. I hear you can program computers to any spec. I wanted to get a p28 chipped to the skunk program and i wanted to have a 8200rpm redline. Is it possible for you to do this. Please drop me an email back. Thanks
Greg,
How much to chip a P28 with a program suitable for Toda Bs? I'm interested. We can take this to e-mail if you would prefer. Thanks.
i guess ill have to plug it in and see...problem is i have nuthin to compare it to cuz i never ran the motor with a GOOD p72 yet...my last one was screwed up
A Type R program on your motor would not help you at all aocnsidereing your motor has a dual-butterfly on the intake manifold.
Unless you get a Type R-style Skunk2 manifold, you'd actually be hurting your power ouput because your secondaries would not be opeming up.
The P28 will NOT run a GS-R motor's secondary butterfly.
i was told that the secondaries were not controled by the ecu
....i do have a skunk2 manifold but its chillin in a box right now and im not sure if i wanna use it...
hey guys, check your emails ... I took it offline.
As for the other gentlemen, yes generally the ecu upgrade is the last mod, however if you know the scope of the plan for your motor build up it can be done anytime based on tried/proven fact. I generally ask for a list of mods or proposed/future mods anyway, so based on that I can determine the ecu upgrade. Any "good" ecu reprogrammer knows that, if they are not asking you those questions then make your own judgement whether you want to use them or not.
Greg
Greg
if you have a GSr and you're running with the stock intake manifold then P72 ecu is the only one you can run with, without loosing the bottom end power
but if skunk2 intake manifold is used then P30, p61, p28, p28, p91 can be used with a good chip/program
if interested i have a P30 with a mugen or spoon program for sale $210 (shipped)
or
P08 chipped with Mugen program (jdm equvalent of p28 but in small case) for $160 shipped...
mugen program doesn;t control the secondaries...5.7k vtec and 8.8k rev limit....max igintion and very rich fuel wise...made 10hp on my b16a
spoon is 5.8k vtec and 8.5k rev limit, more close to stock P30 JDM program, but some improvements...
or
that's what this whole post is about..reread the posts if you didn't get it the first time
[Modified by FAST94GSR, 2:21 PM 10/18/2001]
crashzerothree
Mar 6, 2006 03:17 PM
maxheat
10
Feb 9, 2005 12:55 PM
