Location of parking light wire on 03-04 coupe....
I just installed fog lights on my 7th gen coupe and need help finding the parking light wire for the turn on signal. To those of you who have done this mod, can you please post a picture or a disciption/location of the wire.
Thanks in advance!
Thanks in advance!
PROBLEM SOLVED!
In a moment of clarity I came up with an easy solution. I went back to the rear tail light/bulbs and located the parking light wire with the multitester. It was Red/Black. Then I went up to the kick panel near the fuse block and found the large wire bundle that runs to the rear of the car. I found the same Red/Black wire, tested it and it was the same correct turn on wire. Tapped in there and now my fogs turn on/off with my parking lights by way of the factory stalk switch.
Shhhweet!
Shhhweet!
92B18Bvx
12
May 5, 2004 06:55 AM
