Tranny Rebuild - Manual
Old Mar 7, 2004 | 03:44 PM
ZoominTeg's Avatar
Default Tranny Rebuild - Manual
I just purchased a 98 Integra with 102k miles. The guy told me that it wasn't the car they learned how to drive manual on (thank goodness). He told me that his wife didn't drive it very hard, and that hes done every required Acura Inspection/Maintenance. Now my question is, should I rebuild the tranny, or just change the clutch bearing and flywheel.
Old Mar 7, 2004 | 03:48 PM
lke2drvgsr's Avatar
Default Re: Tranny Rebuild - Manual (Despair447)
um, does it drive ok? if theres nothin wrong with it, why would u need to rebuild it..?
Old Mar 7, 2004 | 03:49 PM
cougar10ag's Avatar
only routine matinence on trannies is change the oil every 30k miles
hows the clutch? if it's good then leave it unless u plan on upgrading it. then i would get that out fo the way
Old Mar 7, 2004 | 03:51 PM
ZoominTeg's Avatar
Default Re: (cougar10ag)
When I test drove it, the clutch was one of the smoothest ever, I'm pretty sure I am gonna put a new flywheel in there. I was asking because I didn't know if Acura maintenance did anything to the clutch.
Old Mar 7, 2004 | 03:53 PM
lke2drvgsr's Avatar
Default Re: (Despair447)
y do u want a new flywheel? do u plan on upgrading ur car or leaving it be? the only required maintenance is the tranny fluid change as cougar stated..
Old Mar 7, 2004 | 04:19 PM
94geeser's Avatar
Despair - you will have a lot of despair when your broke, with no money to spend on upgrades if you are going to throw money at an invisible problem. You said it is one of the smoothest clutches you have ever driven. Leave it alone.
Old Mar 7, 2004 | 04:46 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (94geeser)
If it's not broke, why fix it?
Anyway, I wouldn't worry. There's really not much that can happen to a tranny from someone learning to drive a manual.
Old Mar 7, 2004 | 04:51 PM
ZoominTeg's Avatar
Default Re: (shamoo)
Alright, thanks guys
Borris
Nov 25, 2009 04:11 AM
Nathan007
Jun 12, 2009 05:42 AM
Jk_DC2
Mar 2, 2009 05:27 AM
Jack Black
Apr 2, 2003 03:43 PM
Angry Joe
Sep 12, 2002 09:07 PM
