Bad axle or ball joint?
Old Mar 7, 2004 | 02:21 PM
JinteDgraM's Avatar
Default Bad axle or ball joint?
I was backing out of a parking spot (not a lot of cars) and then i whipped the wheel to the right to swing the front end around to the left. Not THE wisest thing to do but i've dont it many times. Anyways during the turn I heard a big pop. after inspection I pulled the pasenger side trans side CV joint apart inside the boot. so I messed up the axle. But should this have happened? I havn't inspected the ball joint yet.
It was a remanfactured Autozone axle, but i can't imagien the axle should get puleld that much. Is something screwy? thanks.
Old Mar 7, 2004 | 02:23 PM
JinteDgraM's Avatar
Default Re: Bad axle or ball joint? (JinteDgraM)
^ i should be clear that after inspection, i coudl see that I extended the CV joint in the boot from that maneuver.
Old Mar 7, 2004 | 04:36 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
did you drive it after this happened? The only way that the inner joint can be overextended that I know of is if the rest of the axle (the shaft and outboard joint) actually move outwards (as if you were to pull the shaft out w/o dislodging the inner joint first, if that makes any sense). I would definitely check the balljoints and other parts of the suspension to see if anything has come loose.
Old Mar 7, 2004 | 05:36 PM
JinteDgraM's Avatar
Default Re: Bad axle or ball joint? (PatrickGSR94)
yea i had to drive it home. the ONLY thing that was different was the standard "major shaking on acceleration". if i was cruising, nothing was much different. if i had the clutch in, it was 100% normal. and yes, it appears that the axle moved "outward".
Old Mar 7, 2004 | 10:22 PM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JinteDgraM &raquo;</TD></TR><TR><TD CLASS="quote">yea i had to drive it home. the ONLY thing that was different was the standard "major shaking on acceleration". if i was cruising, nothing was much different. if i had the clutch in, it was 100% normal. and yes, it appears that the axle moved "outward".</TD></TR></TABLE>
Well the only way that could have happened was for the entire hub assembly to move outward, thus pulling the axle shaft with it, and overextending the inner joint. Something has definitely broken or come loose on your suspension. Good thing you made it home, you're very lucky it didn't completely fall apart on you. Definitely don't drive the car again until you get it figured out.
Old Mar 8, 2004 | 10:08 AM
JinteDgraM's Avatar
thats so strange, because like i said, its messed up, but overall everything but the axle is still normal. On the way home steering and handling was still tight, no noises, sloshy feel or anything. I will for sure take a look at it when i fix it but what can i look for as in broken loose suspension? how can i "test" my ball joint. I need to drive from IN back to WI this weekend where I will then have lots of time to figure this out, but i NEED to get it home. There is no acura dealer here when i could get a ball joint or something.
Old Mar 8, 2004 | 10:28 AM
MightyMouseTech's Avatar
It was a remanfactured Autozone axle, but i can't imagien the axle should get puleld that much. Is something screwy? thanks.</TD></TR></TABLE>
I hate to sound like a bastard, but,
You buy crap, you get crap.
Old Mar 8, 2004 | 10:30 AM
tobeS2000's Avatar
in my shop we recently had a car come in with what sounds like a similar problem except their axle shot completely out of the tranny and the spindle came off the ball joint which made the tire go sideways and the car had to be towed in ....to be on the safe side we repleaced the axle, spindle ,and ball joint and there have been no complaints thus far and the car runs perfectly
Old Mar 8, 2004 | 02:06 PM
JinteDgraM's Avatar
Default Re: Bad axle or ball joint? (MightyMouseTech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MightyMouseTech &raquo;</TD></TR><TR><TD CLASS="quote">
You buy crap, you get crap.</TD></TR></TABLE>
Yo, that would be the GOOD news. I'm hoping thats the case and that I dont have to fix suspension components. I may replace the ball joint, will a 88-91CRX balljoint fit? Or any other year civic balljoint that I can get from Honda? I know we have autozone and advnaced but i'm not sure about putting generic parts on the car .
Old Mar 8, 2004 | 02:20 PM
JBBNJ609's Avatar
um there is nothing wrong with autozone driveshafts/axles
they arent too much money and have a life time replacement
Old Mar 8, 2004 | 06:04 PM
Default Re: Bad axle or ball joint? (jason bouchard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jason bouchard &raquo;</TD></TR><TR><TD CLASS="quote">
The lifetime replacement thing always bugs me. The crap *** autozones have a lifetime warranty, while OEM NEW joints only have a 1 yr warranty. Which do you think is a bettter joint/lasts longer/find on MY car?
Old Mar 8, 2004 | 07:56 PM
JBBNJ609's Avatar
if your smart enough to replace it yourself then its not too hard to replace it every 2 or so years FOR FREE, and if your snapping axles all the time and dont have the $$$ for DSS axles then this is fine
Old Mar 8, 2004 | 08:47 PM
JinteDgraM's Avatar
replaced the axle tonight, ball joint was fine.. it all visually checked out.. cheap CV joints i suppose. but oh well, all better now, till i do something stupid agian
hcaulfield57
11
Feb 5, 2017 09:19 PM
Rooftop voter
Suspension & Brakes
Apr 9, 2007 08:38 AM
S.Celia
Jan 26, 2004 07:24 AM
Pearce
Oct 16, 2002 10:44 AM
