Best times I've ever pulled... and they still sucked
Well went to the track friday. This made it my 3rd trip to the track in the R and the first since all of these new mods (JDM header, SMSP cat, 9lb fly, ACT XTSS clutch, and new tires). Old mods were only i/e. We took vids but ill have to put them up tues. when i get to work.
First I lowered the tire pressure down to 23 psi. and revved 5,500, I didnt slip the clutch very well and got some mad wheel hop (my radar detector FLEW off my windsheild)
First run:
60': 2.319
330: 6.289
1/8: 9.524
MPH: 75.83
1000: 12.317
1/4: 14.697
MPH: 93.76
2nd run (tried launching higher around 6,500, still got mad wheel hop, but i dont know how, but this was my best for the night 1/4mi time wise, maybe it was my negative R/T of -.163
60': 2.416
330: 6.291
1/8: 9.511
MPH: 76.07
1000: 12.295
1/4: 14.671
MPH: 94.01
3rd run isnt worth listing, i raised the tire pressure back to 35 psi just to see what would happen and ran a 14.9, with a 60' of 2.5
4th run was my best 60' of the night, and still sucked ***. Lowered the press. down to 20psi and I launched around 6,000, slipped the clutch, but then it bogged down to 4,500. I guess I should have slipped it longer.
60': 2.295
330: 6.297
1/8: 9.535
MPH: 75.80
1000: 12.320
1/4: 14.691
MPH: 94.12
5th run was my best trap of the night (I had added a gallon of 100 octane into the mix, I was fixing to run out of gas)
60': 2.311
330: 6.326
1/8: 9.587
MPH: 75.12
1000: 12.395
1/4: 14.761
MPH: 96.91
6th run i pulled a 2.299 60', but still only ran a 14.770@93.92, oh well.
I weighed in at 2495 w/o me in the car. Next time Ill just have to slip the clutch longer
Considering my average last time i was at the track was like a 15.3 these mods have really helped...but on the other hand I ran a 14.878@95.8mph with only and intake. But then it was about 30 degrees cooler and the humidity wasnt a 10th of what it was Fri.
First run:
60': 2.319
330: 6.289
1/8: 9.524
MPH: 75.83
1000: 12.317
1/4: 14.697
MPH: 93.76
):60': 2.416
330: 6.291
1/8: 9.511
MPH: 76.07
1000: 12.295
1/4: 14.671
MPH: 94.01
60': 2.295
330: 6.297
1/8: 9.535
MPH: 75.80
1000: 12.320
1/4: 14.691
MPH: 94.12
60': 2.311
330: 6.326
1/8: 9.587
MPH: 75.12
1000: 12.395
1/4: 14.761
MPH: 96.91
I assume this was at silver dollar?
Keep practicing. When I go (which is very rarely), I get there when they open and get like 3 runs in right after going through tech inspection. You should be able to get ~9 runs before they close. Practice makes perfect. Get some cams + tuning + run open header, and you should be able to drop .5 off your et.
practice. i would try launching a lilttle lower.. 5000-5500, drop the clutch and feather the gas a tiny bit, then go wide open when the tires catch.
i use this method and often pull 2.20-2.25 60fts on Kumho 711 at 32 psi.
try it out next time.
lowering street tire pressure isnt good for high end.. i would just keep them around 30 psi... you're launching at a very high rpm.. this just hurts your clutch when you feather it out..
i just wanna get into VTEC as quickly as possible, which is 5,500 rpms. Thats why i feather it until the road speed equals up to the engine speed. I've figured it out, just havent applied it to the track/real world
And with the xtreme pressure plate, im kinda nervous that the lowly ACT street disc is going to **** on me
thats arent very good times, i ran a 14.2 @ 98.9 mph with a 2.2 60ft with a bone stock R only mod was a aem cold air, my best mph was a 99.3 mph
Thats the problem with launching I have .....
I drop clutch step on gas .... its gonna feel like a 4x4 bumpstop meeting...
should I ride clutch ...?
or...
Feather gas ?
Cuz this fine gentleman seems to have the same problem w/ 60 foot times as me.
or...
Feather gas ?
pretty decent times "98CWITR"....Damn I'd like to run mine just a couple times..thats it.Just to see....but don't care so much about Drag Racing anymore.
14.2 is great...but damn my Friend w/ Toda B's etc,etc only ran 14.2 (granted he only did 1 run) But How's everyone that damn fast STOCK/AEM CAI?
*A diffrent note:
Back in the day on my old GSR I ran a 15.1 @ 98mph--can you belive that!
Lost the slip but I'm sure my 60' was dogshxt----> guess that means had I had good tires..14.2 is what I might have seen?
(JRSC,Tanabe S-med..w/ Ghetto Civic wheels on "Dub caps")
*A diffrent note:
Everyone has different ways of getting a better time.
Your best bet is to KEEP PRACTICING and don't listen to goobers who sit and tell you different ways to launch. You won't learn anything by doing that. Just try different approaches and see what you can do..
yeah i got a slip ill try and find a scanner, btw i ran this at capitol raceway in maryland, you gotta launch the **** out of it ride it a little and stay on the gas and no how to shift fast and at the right time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 »</TD></TR><TR><TD CLASS="quote">yeah i got a slip ill try and find a scanner, btw i ran this at capitol raceway in maryland, you gotta launch the **** out of it ride it a little and stay on the gas and no how to shift fast and at the right time</TD></TR></TABLE>
Ive been to Capitol raceway a couple times for "Grudge Night". Thats a damn good time by the way!!
keep working on your launch, and you can lower your tires pressures even more (~20 psi). You want to get the car to hook up in vtec - that will yield the best times. Also, make sure you have good, sticky tires... don't worry - your times will come down.
I was able to run a 14.6 in my mostly stock ITR (no power steering, unbolted the stock header)
video here:
http://cs.widener.edu/~epanek/...6.mpg
video here:
14.11 w/ JDM header, carsound cat and crappy AO32R's, everything else stock. Full interior, all belts still on the car.
Like mentioned above practice is the key.
60ft....2.1832
1/8et..9.06
1/8mph..80.46
1/4et 14.02
1/4mph 98.77
Did this yesterday at Richmond Dragway. Stock ITR motor in DC2 Integra. The only thing my car has is a cat-back exhaust. This was on street tires(Falken 512) at 22psi. Work on your sixty foot times, it should improve your et.
Forgot to mention, my back seats were taken out too.
1/8et..9.06
1/8mph..80.46
1/4et 14.02
1/4mph 98.77
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R »</TD></TR><TR><TD CLASS="quote">keep working on your launch, and you can lower your tires pressures even more (~20 psi). You want to get the car to hook up in vtec - that will yield the best times. Also, make sure you have good, sticky tires... don't worry - your times will come down.
nice times. You seem to be lacking after the 60'. My best 60' is a 2.18 with a 1/4mile 14.19. My worst 60' was a 2.4 and I still ran a 14.4. I/E 60K on original clutch.Azenis @ 22.5psi..
Try shifting faster and going a little higher in the revs, remember the stock tack reads about 400rpm's higher than it really is. So you should try shifting more towards 9K.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 »</TD></TR><TR><TD CLASS="quote">low to mid 13s this year, no question.</TD></TR></TABLE>
Only if your chasing a Grand Prix up the strip
My best time to date is 13.8x.
The car is a 97 JDM ITR. Only mods: AEM CAI, 2.5" straight exhaust, Poly bushing (firewall only), stripped interior. Falken Azenis and power steering removed.
The car does 13.9-14.1 consistently with full interior.
The track an old WW11 airstrip made of concrete slabs. There is no asphalt or trackbite, definitely not designed for racing. All events are run in the daytime with temperatures of 90-95F and high Jamaican humudity.
60' = 2.0x
ET = 13.9x
trap ~ 102 mph
I dont have the timeslip with me now. I can post specifics if necessary.
60' = 2.0x
ET = 13.9x
trap ~ 102 mph
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie »</TD></TR><TR><TD CLASS="quote">
dood I wasnt even trying, I was just toying with him since he was being such a dick. I woulda had a lot more fun with him if I wasnt pinging
</TD></TR></TABLE>dood I wasnt even trying, I was just toying with him since he was being such a dick. I woulda had a lot more fun with him if I wasnt pinging
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98ITR#0020 »</TD></TR><TR><TD CLASS="quote">nice times. You seem to be lacking after the 60'. My best 60' is a 2.18 with a 1/4mile 14.19. My worst 60' was a 2.4 and I still ran a 14.4. I/E 60K on original clutch.Azenis @ 22.5psi..
Well the tires I am running are 205/50 Yoko. AVS ES100s and were @ 20psi. I am running Kenji so my revlimiter is @ 9,000rpms (tach reads 9,300) and thats where I was shifting. I was getting a lot of wheelhop in 2nd gear and 3rd too, which might be why my trap speeds are slightly lower than they should be. This ACT clutch just ******* grabs like a beast, Ill just have to slip it longer to deture wheelhop and bogging down. I might go back this Friday as long as the weather doesnt heat up too bad. Ill keep you guys posted.
</TD></TR></TABLE>Well the tires I am running are 205/50 Yoko. AVS ES100s and were @ 20psi. I am running Kenji so my revlimiter is @ 9,000rpms (tach reads 9,300) and thats where I was shifting. I was getting a lot of wheelhop in 2nd gear and 3rd too, which might be why my trap speeds are slightly lower than they should be. This ACT clutch just ******* grabs like a beast, Ill just have to slip it longer to deture wheelhop and bogging down. I might go back this Friday as long as the weather doesnt heat up too bad. Ill keep you guys posted.
