What do i need to install the Skunk Camber kit??
Old Mar 7, 2004 | 10:17 AM
Spence's Avatar
Default What do i need to install the Skunk Camber kit??
Hey guys next weekend ill be doing a skunk camber kit install what tools will be needed?
Also anything i should know before i start any tricks?
Old Mar 7, 2004 | 11:34 AM
Spence's Avatar
Default Re: What do i need to install the Skunk Camber kit?? (Spence)
up
Old Mar 7, 2004 | 11:51 AM
GARBhatch.'s Avatar
Camber kit? Front Or back? Upper control arms? Need a little more info than that. But Just make sure you have the balljoints pressed into the control arms before your go taking everything apart. I do not suggest hammering them out of the old ones and into the new ones. Just basic hand tools for that one. 17mm, 14mm, and assorted others. I would also have a jack to put under the lower fork to jack the whole spindle up. This allows you to attach the castle nut to the balljoint easier. Otherwise the damn balljoint will just keep spinning, getting you nowhere in trying to get the castle nut on the threading. AND if this isn't a UCA kit, that's your fault for not specifying that earlier. LOL Good luck and it really isn't bad at all.
Old Mar 7, 2004 | 11:53 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: What do i need to install the Skunk Camber kit?? (GARBhatch.)
use a ball joint seperator. that will be the most helpful tool with this install.
88crx-si
May 9, 2006 07:22 PM
chestnut_55
Oct 23, 2005 03:24 PM
icedaccord19
May 8, 2004 03:31 PM
ForcedAccord
Mar 1, 2002 12:00 PM
TexTeg
Jan 21, 2002 09:25 AM
