Help: Brake Master Cylinder Replacement
Old Mar 7, 2004 | 09:33 AM
onyx00's Avatar
Default Brake Master Cylinder Replacement Help
First off, which part do I need? Just 25? What about 4?
Second, how easy is this? Just throw the new one on? Is there anything special to the install?
Third, what exactly is bench bleeding and do I need/should do it?
Thanks
Old Mar 7, 2004 | 10:59 AM
JeffS's Avatar
Default Re: Brake Master Cylinder Replacement Help (onyx00)
Just buy part #2
Yes, you should bench bleed the MC. How to do this has been covered quite a bit here so I'm not going to retype instructions.
Old Mar 7, 2004 | 03:17 PM
onyx00's Avatar
Default Re: Brake Master Cylinder Replacement Help (JeffS)
What is #2 isn't available? I went to http://www.acuraautomotiveparts.org and the only part they list is #25, no #2 or #4 mentioned anywhere.
Found the stuff on bnech bleeding, took a little more than the usual effort when searching. Thanks.
Old Mar 7, 2004 | 03:29 PM
H-T is CORRUPT's Avatar
bump for an old friend of mine
Old Mar 7, 2004 | 04:13 PM
JeffS's Avatar
You're right... noone seems to be selling that seal. I guess it shouldn't be a big deal to reuse the one you have.
Old Mar 7, 2004 | 05:00 PM
onyx00's Avatar
Final question before I drop $160 on a new master cylinder...
Bled one more time and no air, but the master cylinder make a squeaking sound when I pushed it in. Sound like it is definately bad?
darylcivic
Suspension & Brakes
Mar 14, 2015 06:55 PM
White Boy Hatch
Aug 16, 2012 06:13 PM
JDM_rolex
Jul 24, 2011 11:54 AM
hangac1093
Apr 23, 2006 07:37 PM
jdmcivicferio
Apr 8, 2003 03:19 PM
