Airbag Wiring
I have a 2002 Si steering wheel in my 99 EX Coupe. Is there anyway to wire the airbag from the 2002 to my 99 steering column so that they will be compatible or is there any way to obtain an adapter for this?? I have already re-wired the cruise control successfully but I cant figure out the SRS. Thanks.
I responded to your other post with the same post also:
I have a JDM RSX R wheel on my 00 CIVIC SIR = USDM SI
The airbag plug is a 2 wire connector. and the JDM airbag is also a 2 wire connector.
The USDM Si and RSX wheel is a 4 wire connector.
There is a member on clubsi.com that has the USDM SI wheel in his car Pm for his screen name.
Can you tell me how you re wired the cruise control? I would like to hook mine up. Also which switch did u use?
pics of the wheel installed:
Thanks
Thanks
PSU
Apr 14, 2006 01:03 PM
CivicSI93
Oct 26, 2005 07:13 AM
