Airbag Wiring
Airbag Wiring
I have a 2002 Si steering wheel in my 99 EX Coupe. Is there anyway to wire the airbag from the 2002 to my 99 steering column so that they will be compatible or is there any way to obtain an adapter for this?? I have already re-wired the cruise control successfully but I cant figure out the SRS. Thanks.
Re: Airbag Wiring (remborsky)
I responded to your other post with the same post also:
I have a JDM RSX R wheel on my 00 CIVIC SIR = USDM SI
The airbag plug is a 2 wire connector. and the JDM airbag is also a 2 wire connector.
The USDM Si and RSX wheel is a 4 wire connector.
There is a member on clubsi.com that has the USDM SI wheel in his car Pm for his screen name.
Can you tell me how you re wired the cruise control? I would like to hook mine up. Also which switch did u use?
pics of the wheel installed:
Thanks
Thanks
Re: Airbag Wiring (CIVIC dude)
good luck getting it all wired up right, i would help you do it but i dont know.. i love that steering wheel.. i wish it would fit on my eg civic...
PSU
04-14-2006 01:03 PM
CivicSI93
10-26-2005 07:13 AM
