What are all you STOCK Block Boys running?
Old Mar 7, 2004 | 06:43 AM
RedStarGsr's Avatar
Default What are all you STOCK Block Boys running?
im talking stock pistons, rods, sleeves, everything... i guess i can let head studs slide or any other headwork, but just curious how much boost / whp you guys are putting down safely.
Trying to get a feel for how much I should psi i should push (right now i haven't obtained a whp goal, my goal was to build a reliable (first) very quick street car that didnt die off up high) but i would like to be in the 13s without slicks
yea yea i know, 1/4 mile times and whp are two different things, but im BASICALLY TRYING TO FIGURE OUT HOW MUCH WHP PEOPLE ARE MAKING AND RUNNING SAFELY ON STOCK BLOCKS...
I'd also appreciate it if you could post either a dyno chart, which turbo, which engine with c/r, what management you are using, with what a/r curve...thanks a lot guys. i appreciate it.
ill start...currently runnin a b17 with a 60/48 t3 8psi (kinda want a 63ar...4200rpms at 80mph is touchy w/ boost), haven't touched a dyno yet, but after some small kinks will be tuning through an innovate wideband and chrome.
Old Mar 7, 2004 | 07:38 AM
B18bEK's Avatar
it would be alot easier to search for LS dyno sheets, ect ...
but 323hp 270tq @12.5psi hondata
Old Mar 7, 2004 | 07:41 AM
Mad Cow's Avatar
Default Re: What are all you STOCK Block Boys running? (RedStarGsr)
At this point in time, I'm making an amazing 197.4whp and 148tq on my GS-R with SC61. I feel this is a very safe level...
Once my wastegate is fixed(read: replaced), and I can run more than 4psi... I'll be good for much more power.
Old Mar 7, 2004 | 07:44 AM
quikB18B's Avatar
Default Re: What are all you STOCK Block Boys running? (MadCow)
Turbo Ls here
Sc34
3" exhuast
Hondata/550cc
Stock motor
Stock intake manifold
271/253 on 1 bar, tuned conservatively a/f about 11.8
Old Mar 7, 2004 | 03:51 PM
RedStarGsr's Avatar
Default Re: What are all you STOCK Block Boys running? (quikB18B)
thanks==
here is why i ask--
the richer the a/r, and the more you retard the engine, the safer your 'tune' is correct?
well... to achieve more power you want a (not extremely) 'lean'er tune and a little more advanced timing (say around .4 per pound)... now if you want to be safe and run 15psi but make it a little more rich than usual, and retard about a degree per pound, what is holding you back from cranking up the boost?
i love my car as much as the next guy, but i dont have every waking minute so spend with it...in fact im putting in around 60 hours a week right now, and im just trying to learn a little while i go...
what is considered a good tune? an even a/r? my brother and i share the innovate wideband and he works through chrome...just trying to figure a safe way of increasing power before i move to my next block...
Old Mar 7, 2004 | 04:23 PM
VTC_CiViC's Avatar
293whp with an ultra rich A/F on a stock B18C1.. coulda made more if the laptop didn't quit at the dyno.
Old Mar 7, 2004 | 11:54 PM
RedStarGsr's Avatar
nice numbers, what psi?---bump for the nite
Old Mar 8, 2004 | 04:11 AM
GDM Z28's Avatar
Default Re: (RedStarGsr)
242/221 on a stock LS with a 50 trim t3 (baby turbo). could of made more but i didnt want Dave to add more timing even though he said i could.
BTW i ran a 13.6 @ 109 with a 2.6 60ft.
all of this is on uberdata
Old Mar 8, 2004 | 04:32 AM
RedTegLS's Avatar
Default Re: (civicflnum1)
#'s in the sig. I think you can make it bigger by adding .orig to the end of the url.
Old Mar 8, 2004 | 05:24 AM
Charlie Moua's Avatar
I was looking for the same answer as you are.
I found that there are too many varibles in play as in what is safe and not.
for honda motor (STOCK) D, B, H, Fseries it seems that 7psi on a medium size t3t4 + fmu setup running rich is concidered fairly safe.
So it really depends on what turbo and motor you have.
I have a b18c1 with a small bb apexi turbo so 7psi on a t3t4 would not be the same as 7psi on my apexi turbo. So I would need to push about 10psi to achive that same 7psi affect of the t3t4.
Also for gsr the max whp on a DAILY driven car I would run... meaning SAME PSI all the time is 7psi (t3t4 size turbo) which equals roughly 230 to 240whp
4psi would be about 200whp
Also tunning plays the final role in who much you can boost CONSISTANTLY on a stock block.
HTH
Old Mar 8, 2004 | 05:43 AM
turbosi03's Avatar
268whp @10psi
Bone stock B16A2
drag 3 kit
S100b Hondata
780cc injectors (was for built motor)
Old Mar 8, 2004 | 05:47 AM
MIKES's Avatar
Default Re: What are all you STOCK Block Boys running? (turbosi03)
That would depend on your tuner and his ability to fine tune. Also depends on how much ***** you got when they are tuning (At what boost level do you say quits to).
Old Mar 8, 2004 | 05:49 AM
Jdm93civic's Avatar
well i know someone that has a stock block gsr i think only block guard not sure i think straight t4 turbo and it runs safe the whole time..ran like low 11s at the track i think..
Old Mar 8, 2004 | 07:23 AM
swlabhot's Avatar
Default Re: (Jdm93civic)
B18C6. 11.0:1 CR. 10psi - 300+hp
Old Mar 8, 2004 | 07:25 AM
TurboJesse
Guest
Posts: n/a
Default Re: (swlabhot)
B16a....Ran outa injector so had to stop
Old Mar 8, 2004 | 07:28 AM
infra's Avatar
Default Re: (Mpir3)
what fuel management?
Old Mar 8, 2004 | 07:32 AM
JDogg's Avatar
Default Re: (infra)
300hp, 190tq with sc61 on stock block b16, 8psi
overblown manifold and downpipe
je intake manifold
aem ems.
Old Mar 8, 2004 | 08:20 AM
gelok's Avatar
Default Re: (JDogg)
check my sig.
hondata s200b
3" cutout
dsm 450cc inj.
Old Mar 8, 2004 | 08:43 AM
DOHCarp's Avatar
Don't know what my final HP numbers where but I ran 11.99 @ 112 MPH in the 1/4. Bone stock just put a vtec head on my b18b.
Old Mar 8, 2004 | 08:55 AM
89 CRX SI's Avatar
Default Re: What are all you STOCK Block Boys running? (DOHCarp)
alot of you guys are running hondata, its such a nice system but out of my reach....
I think the afc- hack is sufficient for my setup of 10 psi small t-25 intercooled to a b16a2 in a ef civic... im still building it but obviously i will upgrade to hondata but this will do for now....
it all depends on size of turbo, how strong is the motor, compression ratio, a/f ,temps like everything..... haha
A good tuner will find how much you can do once your setup is done...
Tory
Old Mar 8, 2004 | 08:56 AM
illi Adik's Avatar
Excellent post, I'm in the same boat..keep em coming.
Old Mar 8, 2004 | 09:11 AM
RedStarGsr's Avatar
my setup consists of...
60 trim 48 ar t3 8psi
2.5" downpipe into 3" exhaust
450cc
uberdata
innovate wideband
some other air goodies (itr mani, 64mmTb, etc.)
b17 with stock 9.6 c/r
no numbers yet...but im guessing what should i shoot for for an a/r, think 11.8 or so? also, im retarding about 1 pound per degree,
dam some of these numbers are amazing...
Old Mar 8, 2004 | 09:31 AM
99lspwr's Avatar
I hit 230 whp/ 217 tq. on 10 psi...
See sig for other info....
Old Mar 8, 2004 | 11:29 AM
turbologist's Avatar
Default Re: (99lspwr)
My old setup....
325whp/ 229ft. lbs tq @12psi
Old Mar 8, 2004 | 11:52 AM
Nextelbuddy's Avatar
Default Re: (Turbologist)
my old setup stock block b18c1
326 hp and 226 tq @ 12 psi
