tranny issue, gears kinda stick when try and pull out
Old Mar 6, 2004 | 11:25 PM
TyPe_R_GuY's Avatar
Default tranny issue, gears kinda stick when try and pull out
I recently got the JDM Final Drive installed along with a lightweight flywheel and good clutch, and everything has turned out good so far. But recently, when I drive normal everything shifts just fine or if i go through my gears fast (redlining each) it goes okay too, but say i drop 2nd *redline* go to 3rd then let off, when i try and **** to forth normally, i can feel it kinda stick/a tiny bit harder to pull out of gear, does anyone know what could be causing this?? thanks for any help you can give
Old Mar 7, 2004 | 10:17 AM
TyPe_R_GuY's Avatar
anyone?
Old Mar 7, 2004 | 08:02 PM
Dan GSR's Avatar
Default Re: (TyPe_R_GuY)
hard to say,
seeing as you aren't that familiar with trans internals
its possible that you still put it together incorrectly
ProBlackHawk
Aug 25, 2012 11:25 PM
Suck my DX
May 27, 2005 06:14 PM
TyPe_R_GuY
Feb 25, 2004 09:53 PM
jdmhondageek
22
May 3, 2003 07:34 PM
StinkyTofu
May 27, 2002 06:33 PM
