Thermostat problem?!?!?!?
Old Mar 6, 2004 | 07:07 PM
Egone's Avatar
Default Thermostat problem?!?!?!?
my temperature guage before use to stay at the bottom line of the guage unless i let it idle for a long time then it would climb to the middle so i figured it was the termostat so i changed it and today the temperature needle doesnt even move now its just stays at C what could be wrong? the sensor?
Old Mar 9, 2004 | 08:46 PM
Egone's Avatar
where would that be located beneath the distributor??
Old Mar 9, 2004 | 09:05 PM
tominos's Avatar
Default Re: Thermostat problem?!?!?!? (Egone)
the temp needle is supposed to be at the middle(normal operating temp), if it ain't broke don't fix it... when your car warms up( when the needle is at the middle), feel the lower radiator hose and see if it's cold or warm.
Old Mar 9, 2004 | 09:24 PM
Egone's Avatar
before my temp needle was at the lower white line thats the max it will go now the temp guage doesnt even work and also before my lower rad hose was cold even warm just cold now its a lil hot/warmish but the guage doesnt work so im thinking sensor?
Old Mar 9, 2004 | 09:45 PM
tominos's Avatar
Default Re: (Egone)
so your temp gauge doesn't work even when the engine is fully warm? since the lower radiator hose is hot/warm, that means the thermostat is working.
if you suspect the gauge to be faulty, unplug the temp sensor and ground out the terminals... your gauge should be at full deflection. if it still doesn't move, your gauge is faulty. err at least i think thats how you would go about testing it, don't have my helms near me but hope that helps.
Old Mar 9, 2004 | 10:35 PM
Egone's Avatar
ya well if i let the car idle for a long time she goes up to the bottom white line as soon as i drive it goes all the way down to C again and yes the system is fully bleed
TOO MUCH TORQUE
Jul 28, 2010 09:21 PM
Dave9212
Jun 11, 2008 05:23 PM
E JAY 1
Apr 26, 2008 10:02 AM
MikeLuder
Feb 19, 2008 10:53 AM
Mikey
Jan 8, 2005 08:03 AM
