Exhaust setup... Q's on flange and spring bolts.
Old Mar 6, 2004 | 06:32 PM
X2BOARD's Avatar
Default Exhaust setup... Q's on flange and spring bolts.
I am going to be replacing my cat w/ straight pipe.... but have some questions...
If I replace the cat w/ test pipe and only flange the section to the header... but weld it to the rest of the B pipe, will that put too much pressure on the header flange/spring bolts ?
Old Mar 6, 2004 | 10:31 PM
IN VTEC's Avatar
Default Re: Exhaust setup... Q's on flange and spring bolts. (X2BOARD)
The 3-bolt flange on the end of the cat is a fixed design as well and just as rigid as not having a flange at all there.
Old Mar 7, 2004 | 10:19 AM
X2BOARD's Avatar
OK....that answers that.... so basically, I should not have any developing leaks.
I'll be doing Header to flange... solid piping to a flanged muffler. sounds kosher ?
**Just want to ensure I get no leaks or excessive stress on the header.
Bloody Hatch
Sep 18, 2012 05:59 PM
idrivealude
Sep 15, 2008 03:28 PM
polishedturd
Mar 16, 2008 03:11 PM
GiT LaO'd
Feb 7, 2007 01:22 PM
jfingers
Jan 4, 2005 12:33 PM
