*** Question on Offset for 16" Wheels ***
Old Mar 6, 2004 | 06:09 PM
chau003's Avatar
Default *** Question on Offset for 16" Wheels ***
I plan on getting 16x7 wheels and they have an offset of +42. I also plan on dropping the prelude with eibach sportlines (1.7 front and 1.5 rear). Will the wheels rub with this setup? I was looking at a sticky they have over at another honda prelude forum and it said that there is a possibility of rub depending on the drop but it didnt say how much or little of a drop causes wheel rub. Any help would be appreciated. TIA.
Oh.. I have a gen. 4 if that makes any difference.
- I don't know the proper etiquette on linking to other forums, but if its ok.. i'll post the link to it, I found it really helpful.
Old Mar 6, 2004 | 06:17 PM
bad-monkey's Avatar
Default Re: *** Question on Offset for 16" Wheels *** (chau003)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chau003 &raquo;</TD></TR><TR><TD CLASS="quote">I plan on getting 16x7 wheels and they have an offset of +42. I also plan on dropping the prelude with eibach sportlines (1.7 front and 1.5 rear). Will the wheels rub with this setup? I was looking at a sticky they have over at another honda prelude forum and it said that there is a possibility of rub depending on the drop but it didnt say how much or little of a drop causes wheel rub. Any help would be appreciated. TIA.
- I don't know the proper etiquette on linking to other forums, but if its ok.. i'll post the link to it, I found it really helpful. </TD></TR></TABLE>
hard to say, it's in that grey area.
shave that tab in the rear fenderwell and it MIGHT work, depending on what tires you're on.
Old Mar 6, 2004 | 06:50 PM
Asian Persuasion's Avatar
If you were a 5gen I'd definitely say you'd be good to go. I have +40 offset on my 16x7 wheels. All I had to do was trim the tab in the rear fenderwell and I was good to go.
Old Mar 6, 2004 | 08:19 PM
chau003's Avatar
I'm sorry.. when you guys say trim the tab, could you post a pic of it? I'm more of a visual learner than vocal. A.D.D. owns me..
Old Mar 7, 2004 | 02:08 AM
bad-monkey's Avatar
Default Re: (chau003)
hmm i don't know if anyone has any pictures around but,
if you look in the rear wheelwell, you'll see towards the aft of the car, a place where the rear bumper meets the quarterpanel. there's a screw holding the 2 together. the place where they meet has a little plastic tab that kind of sticks out .5" into the wheelwell from the body. take a dremel and trim off the extra plastic.
KashMillien
Aug 19, 2015 07:12 PM
wtfitzphat
Aug 30, 2008 08:50 AM
90hbvtec
Mar 1, 2007 04:22 AM
DarkBB4
Jun 8, 2005 01:29 AM
