H series to B series Adapter plate .....Has began.....
Old Mar 6, 2004 | 04:13 PM
Maddox's Avatar
Default H series to B series Adapter plate .....Has began.....
I have started on the H series to B series adapter plate. Last night I got the whole templet done. Im going to machine the plate out with a alum sheet at work. I have some pictures of the templet. I will post them on here later.
As for people asking questions about the starter not lining up or the input shaft not going in far enough. They all work. Everything should be done and togethere by mid next week....
Old Mar 6, 2004 | 04:30 PM
alloutmotor's Avatar
wow..this is going to be very good....what is the price going to look like..i hope its not ridiculous
Old Mar 6, 2004 | 05:12 PM
Maddox's Avatar
I was going to just make one for me.. for my project... I was thinking about selling them..
Old Mar 6, 2004 | 07:52 PM
Jays91DXhatch's Avatar
Default Re: (AllMotorCRX161)
I'd buy one depending on price.
Only reason I didn't put a H22 in my EF was the mounts but if this would require me to just get a new drivers side mount, and I could still use my cable B series tranny...I'd hit it up for sure.
Old Mar 6, 2004 | 08:05 PM
The Internet Tough Guy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorCRX161 &raquo;</TD></TR><TR><TD CLASS="quote"> I was thinking about selling them..</TD></TR></TABLE>
i'd think about that a little more. you could really make a good bit of $$$ from that. i know the only think that kept me from going h22 was the damn tranny. plus i bet most everybody with the h22 in already would jump on it.
Old Mar 6, 2004 | 08:36 PM
Maddox's Avatar
the way that im designing the plate is you can use your Hasport mounts. I have all 3 of my mounts on the motor and they seem to be all lining up perfect so far. I will not know for sure until the motor is in the car.
I will be able to use my 90-93 axles, midshaft, hasport mounts, linkage and most important use my LSD cable tranny
Old Mar 10, 2004 | 02:19 PM
Ryan C's Avatar
Old Mar 10, 2004 | 06:03 PM
TOM J's Avatar
Old Schooler
Default Re: H series to B series Adapter plate .....Has began..... (AllMotorCRX161)
This plate is avaliable at RS machine Not sure of the price 310-328-5514
Old Mar 14, 2004 | 12:40 AM
Maintenance's Avatar
Default Re: H series to B series Adapter plate .....Has began..... (TOM J)
updates?
Old Mar 14, 2004 | 07:46 AM
Maddox's Avatar
Go here for updates
https://honda-tech.com/zerothread?id=790499
Old May 28, 2004 | 12:08 PM
4drEF's Avatar
Keyboard Humorist
Updates?
That thread you posted is locked.
Does this mean that your adaptor plate project is locked down too?
Old May 28, 2004 | 03:08 PM
H25's Avatar
H25
Default Re: (4drEF)
what are you going to do about the clutch? the input shaft wont sldie into the clutch and flywheel the same anymore. due to the thickness of the adapter plate. just something to think about.
Old May 28, 2004 | 03:22 PM
Rick Solis's Avatar
Default Re: (MHRacing-310)
Run a custom thicker flywheeel to make up for the gap added by the adapter plate...
If you use the factory B series tranny mount and build the other mounts around that you will be able to run the stock B series shift linkage...
Something to consider though, the H motor sits further back, more upright than the B motor does so the plate may have to have offset holes drilled to compensate for the mis aligned H block and B tranny bolt holes. If you just slap the 2 together with out proper clocking or degreeing of the 2 you may run into axle alignment issues...
As for intermediate shaft... You can fab a new block mount plate on the B series shaft to bolt to the H block... This will enable you to use stock B axles granted that everything is in line in terms of positioning...
I looked into this a while back but kinda ditched the idea with hopes that companies such as HASport, HCP and others of the like would take it a step further... i know RS has a plate that they are working on but not to sure if its 100% ready to go yet. I know Mike is a perfectionist when it comes to stuff like that and I know that he wont put anything out there that is less than perfect...
Old May 28, 2004 | 09:14 PM
chris_m's Avatar
* B A N N E D *
Default Re: (Rick Solis)
dh-racing.com has built 2 already both h to b series. Holding up well so far.
Old May 28, 2004 | 09:29 PM
ShaunRR's Avatar
HT White Ops
Community Builder
This is great. The H was my dream swap when I first got into Hondas, until I learned about the problems caused by the extreme axle angles involved.
Old Aug 27, 2004 | 01:01 PM
GimpyAccord's Avatar
Default Re: H series to B series Adapter plate .....Has began..... (rochesterricer)
anymore info
Old Aug 27, 2004 | 02:16 PM
jdmh22eg's Avatar
Default Re: H series to B series Adapter plate .....Has began..... (GimpyAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorCRX161 &raquo;</TD></TR><TR><TD CLASS="quote">Go here for updates
https://honda-tech.com/zerothread?id=790499</TD></TR></TABLE>
read all the way through...
Old Aug 28, 2004 | 03:59 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rick Solis &raquo;</TD></TR><TR><TD CLASS="quote">Run a custom thicker flywheeel to make up for the gap added by the adapter plate...</TD></TR></TABLE>
An easier and cheaper way to go would be to make a flywheel spacer. This would consis simply of a metal disk of the same thickness as the adaptor plate bolted between the flywheel and the end of the crank. Longer bolts would be required, of course.
Old Oct 14, 2004 | 09:50 AM
CivicManLs's Avatar
how can I buy one? I am buying anh22 swap, but I want to use my b16 tranny because the shorter gear ratio's combined with the power of the h22 will make it an insane ride.
jseaton357
55
Oct 15, 2017 02:32 AM
thegatekeeper14
Transmission & Drivetrain
Dec 30, 2009 07:31 PM
thegatekeeper14
Welding / Fabrication
Dec 20, 2009 06:25 PM
want2rally
Sep 6, 2005 05:57 PM
Maddox
216
May 14, 2004 05:07 AM
