what could happen if your chain is too tight
you ever see the AOL HIGHSPEED commerical......well if your chain is to tight thats what happens you go so fast you cant control it and as soon as accelerate from 0-80 in 2.3 seconds your stock flux capacotor kicks in and takes you back to 1980.............
lol anyway....if its to loose it can grind away the teeth on the sprokets
your fine with a 1/2 inch......nothing to worry about
steve
steve
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10seconds »</TD></TR><TR><TD CLASS="quote">your fine with a 1/2 inch......nothing to worry about
HAHAHAHA
Seriously, though, having a chain that's too tight can be detrimental to your suspension settings, making your bike extremely twitchy. I'm not sure what the freeplay is supposed to be, but check the owner's manual.
HAHAHAHA
Pros-
it's not too loose
Cons-
increased component wear, particularly the countersprocket and shaft
decreased suspension travel
decreased chain life do to the above
loss of applied power due to greater drivetrain loss (not much but it's there)
it's not too loose
Cons-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10seconds »</TD></TR><TR><TD CLASS="quote">you ever see the AOL HIGHSPEED commerical......well if your chain is to tight thats what happens you go so fast you cant control it and as soon as accelerate from 0-80 in 2.3 seconds your stock flux capacotor kicks in and takes you back to 1980......</TD></TR></TABLE>
hahaha
just keep it around 1/2 in. like everyone's sayin.
hahaha
Half an inch is way too tight. Once you sit on the bike and compress the suspension then there is probably no slack at all. Loosen it up a bit. About half an inch with the suspension compressed is good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civbeater90 »</TD></TR><TR><TD CLASS="quote">pros and cons of having your chain with very littleslack.
cbr f2 with about 1/2 inch</TD></TR></TABLE>
Pro's ....nothing
Con's....
reduce chain life
reduce gearbix bearing life
reduce power
decrease handling
Go and get a a Scottoiler and adjust it, simple.
Pro's ....nothing
Con's....
reduce chain life
reduce power
decrease handling
I Want An Si
Honda Motorcycles
Nov 11, 2005 06:17 PM
ngng
Honda Motorcycles
11
Jul 24, 2005 10:44 AM
